Commit 7c81197d authored by Quentin Khan's avatar Quentin Khan
Added FFmmAlgorithmThreadBalance to PerfTest
AlgoLoaderThreadBalance: file creation
PerfTest : Added FFmmAlgorithmThreadBalance test
parent a2549086
// ==== CMAKE ====
// Keep in private GIT
// @SCALFMM_PRIVATE
#ifndef _ALGOLOADERTHREADBALANCE_HPP_
#define _ALGOLOADERTHREADBALANCE_HPP_
#include <memory>
#include <sstream>
#include "PerfTestUtils.hpp"
#include "Core/FFmmAlgorithmThreadBalance.hpp"
template <class _TreeLoader, template<typename> class _KernelLoader>
class AlgoLoaderThreadBalance : public FAlgoLoader<_TreeLoader, _KernelLoader> {
public:
using TreeLoader = _TreeLoader;
using KernelLoader = _KernelLoader<TreeLoader>;
using FReal = typename TreeLoader::FReal;
using CellClass = typename TreeLoader::CellClass;
using ContainerClass = typename TreeLoader::ContainerClass;
using LeafClass = typename TreeLoader::LeafClass;
using OctreeClass = typename TreeLoader::OctreeClass;
using KernelClass = typename KernelLoader::KernelClass;
using FMMClass = FFmmAlgorithmThreadBalance<OctreeClass, CellClass, ContainerClass, KernelClass, LeafClass>;
TreeLoader& _treeLoader;
KernelLoader& _kernelLoader;
std::unique_ptr<FMMClass> _algo;
AlgoLoaderThreadBalance(FPerfTestParams& params,
TreeLoader& treeLoader,
KernelLoader& kernelLoader) :
_treeLoader(treeLoader),
_kernelLoader(kernelLoader),
_algo(nullptr) {
void run() {
_algo = std::unique_ptr<FMMClass>(
new FMMClass(&(_treeLoader._tree), &(_kernelLoader._kernel)));
_algo->execute();
virtual std::string getRunInfoString() const {
return "";
#endif
...@@ -31,6 +31,7 @@ ...@@ -31,6 +31,7 @@
#include "AlgoLoaderTask.hpp" #include "AlgoLoaderTask.hpp"
#include "AlgoLoaderSectionTask.hpp" #include "AlgoLoaderSectionTask.hpp"
#include "AlgoLoaderCostZones.hpp" #include "AlgoLoaderCostZones.hpp"
#include "AlgoLoaderThreadBalance.hpp"
* \brief Runs a generic sequence of actions to use an algorithm. * \brief Runs a generic sequence of actions to use an algorithm.
...@@ -115,6 +116,8 @@ int main (int argc, char** argv) ...@@ -115,6 +116,8 @@ int main (int argc, char** argv)
runperf<TreeLoaderFCheb<>, KernelLoaderFChebSym, AlgoLoaderCostZones>(params); runperf<TreeLoaderFCheb<>, KernelLoaderFChebSym, AlgoLoaderCostZones>(params);
} else if ( "sectiontask" == params.algo ) { } else if ( "sectiontask" == params.algo ) {
runperf<TreeLoaderFCheb<>, KernelLoaderFChebSym, AlgoLoaderSectionTask>(params); runperf<TreeLoaderFCheb<>, KernelLoaderFChebSym, AlgoLoaderSectionTask>(params);
} else if ( "autobalance" == params.algo ) {
runperf<TreeLoaderFCheb<>, KernelLoaderFChebSym, AlgoLoaderThreadBalance>(params);
} else { } else {
std::cout << "Unknown algorithm: " << params.algo << std::endl; std::cout << "Unknown algorithm: " << params.algo << std::endl;
