Commit 7bc2123a authored by COULAUD Olivier's avatar COULAUD Olivier
Remove USE_BLAS
parent 820462de
...@@ -15,7 +15,6 @@ ...@@ -15,7 +15,6 @@
// ==== CMAKE ===== // ==== CMAKE =====
// @FUSE_BLAS
// @FUSE_FFT // @FUSE_FFT
// Keep in private GIT // Keep in private GIT
...@@ -30,9 +29,6 @@ ...@@ -30,9 +29,6 @@
#include "Utils/FTic.hpp" #include "Utils/FTic.hpp"
#include "Containers/FOctree.hpp" #include "Containers/FOctree.hpp"
//#include "Containers/FVector.hpp"
//#include "Components/FSimpleLeaf.hpp"
#include "Utils/FPoint.hpp" #include "Utils/FPoint.hpp"
...@@ -102,15 +98,12 @@ int main(int argc, char ** argv){ ...@@ -102,15 +98,12 @@ int main(int argc, char ** argv){
// const unsigned int NbThreads = FParameters::getValue(argc, argv, FParameterDefinitions::NbThreads.options, 1); // const unsigned int NbThreads = FParameters::getValue(argc, argv, FParameterDefinitions::NbThreads.options, 1);
// accuracy // accuracy
const unsigned int P = 5 ; const unsigned int P = 7 ;
const int sminM = FParameters::getValue(argc,argv,LocalOptionMinMultipoleThreshod.options, P*P*P); const int sminM = FParameters::getValue(argc,argv,LocalOptionMinMultipoleThreshod.options, P*P*P);
const int sminL = FParameters::getValue(argc,argv,LocalOptionMinLocalThreshod.options, P*P*P); const int sminL = FParameters::getValue(argc,argv,LocalOptionMinLocalThreshod.options, P*P*P);
// typedef FTestCell CellClass;
// typedef FAdaptiveTestKernel< CellClass, ContainerClass > KernelClass;
typedef FUnifCell<P> CellClass; typedef FUnifCell<P> CellClass;
typedef FP2PParticleContainerIndexed<> ContainerClass; typedef FP2PParticleContainerIndexed<> ContainerClass;
typedef FSimpleIndexedLeaf<ContainerClass> LeafClass; typedef FSimpleIndexedLeaf<ContainerClass> LeafClass;
...@@ -191,8 +184,9 @@ int main(int argc, char ** argv){ ...@@ -191,8 +184,9 @@ int main(int argc, char ** argv){
std::cout << "Working on particles ..." << std::endl; std::cout << "Working on particles ..." << std::endl;
counter.tic(); counter.tic();
const MatrixKernelClass MatrixKernel; const MatrixKernelClass MatrixKernel;
KernelWrapperClass kernels(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(),&MatrixKernel,sminM,sminL); // FTestKernels FBasicKernels KernelWrapperClass *kernels = new KernelWrapperClass(TreeHeight, loader.getBoxWidth(),
FmmClass algo(&tree,&kernels); //FFmmAlgorithm FFmmAlgorithmThread loader.getCenterOfBox(),&MatrixKernel,sminM,sminL); // FTestKernels FBasicKernels
FmmClass algo(&tree,kernels); //FFmmAlgorithm FFmmAlgorithmThread
// For debug purpose // For debug purpose
// Set Global id // Set Global id
...@@ -200,7 +194,7 @@ int main(int argc, char ** argv){ ...@@ -200,7 +194,7 @@ int main(int argc, char ** argv){
long int idCell = setGlobalID(tree); long int idCell = setGlobalID(tree);
algo.execute(); algo.execute();
counter.tac(); counter.tac();
std::cout << "Done " << "(@Algorithm = " << counter.elapsed() << " s)." << std::endl; std::cout << "Done " << "(@Algorithm = " << counter.elapsed() << " s)." << std::endl;
Supports Markdown
