Commit 6ee40a3c authored by berenger-bramas's avatar berenger-bramas
Add the periodic functions in the new kernel.
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/scalfmm/scalfmm/trunk@306 2616d619-271b-44dc-8df4-d4a8f33a7222
parent acb2dfc8
...@@ -20,9 +20,11 @@ ...@@ -20,9 +20,11 @@
template< class ParticleClass, class CellClass, class ContainerClass> template< class ParticleClass, class CellClass, class ContainerClass>
class FElecForcesKernels : public FAbstractKernels<ParticleClass,CellClass,ContainerClass> { class FElecForcesKernels : public FAbstractKernels<ParticleClass,CellClass,ContainerClass> {
int devP; //< The P const int devP; //< The P
int devM2lP; //< A secondary P const int devM2lP; //< A secondary P
int treeHeight; //< The height of the tree const FReal boxWidth; //< the box width at leaf level
const int treeHeight; //< The height of the tree
FHarmonic harmonic; //< The harmonic computation class FHarmonic harmonic; //< The harmonic computation class
FComplexe* preL2LTransitions; //< The pre-computation for the L2L based on the level FComplexe* preL2LTransitions; //< The pre-computation for the L2L based on the level
...@@ -41,7 +43,7 @@ class FElecForcesKernels : public FAbstractKernels<ParticleClass,CellClass,Conta ...@@ -41,7 +43,7 @@ class FElecForcesKernels : public FAbstractKernels<ParticleClass,CellClass,Conta
/** Alloc and init pre-vectors*/ /** Alloc and init pre-vectors*/
void allocAndInit(const FReal boxWidth){ void allocAndInit(){
preL2LTransitions = new FComplexe[treeHeight * 8 * harmonic.getExpSize()]; preL2LTransitions = new FComplexe[treeHeight * 8 * harmonic.getExpSize()];
preM2MTransitions = new FComplexe[treeHeight * 8 * harmonic.getExpSize()]; preM2MTransitions = new FComplexe[treeHeight * 8 * harmonic.getExpSize()];
...@@ -97,11 +99,21 @@ class FElecForcesKernels : public FAbstractKernels<ParticleClass,CellClass,Conta ...@@ -97,11 +99,21 @@ class FElecForcesKernels : public FAbstractKernels<ParticleClass,CellClass,Conta
public: public:
/** Kernel constructor */ /** Kernel constructor */
FElecForcesKernels(const int inDevP, const int inTreeHeight, const FReal boxWidth) FElecForcesKernels(const int inDevP, const int inTreeHeight, const FReal inBoxWidth)
: devP(inDevP), devM2lP(int(((inDevP*2)+1) * ((inDevP*2)+2) * 0.5)), treeHeight(inTreeHeight), harmonic(inDevP), : devP(inDevP), devM2lP(int(((inDevP*2)+1) * ((inDevP*2)+2) * 0.5)), boxWidth(inBoxWidth),
preL2LTransitions(0), preM2MTransitions(0), preM2LTransitions(0) {
allocAndInit();
/** Copy constructor */
FElecForcesKernels(const FElecForcesKernels& other)
: devP(other.devP), devM2lP(other.devM2lP), boxWidth(other.boxWidth),
treeHeight(other.boxWidth), harmonic(other.devP),
preL2LTransitions(0), preM2MTransitions(0), preM2LTransitions(0) { preL2LTransitions(0), preM2MTransitions(0), preM2LTransitions(0) {
allocAndInit(boxWidth); allocAndInit();
/** Default destructor */ /** Default destructor */
...@@ -141,14 +153,14 @@ public: ...@@ -141,14 +153,14 @@ public:
const int size, const int inLevel) { const int size, const int inLevel) {
const FTreeCoordinate& coordCenter = pole->getCoordinate(); const FTreeCoordinate& coordCenter = pole->getCoordinate();
// For all neighbors compute M2L // For all neighbors compute M2L
for(int idxSize = 0 ; idxSize < size ; ++idxSize){ for(int idxNeigh = 0 ; idxNeigh < size ; ++idxNeigh){
const FTreeCoordinate& coordNeighbors = distantNeighbors[idxSize]->getCoordinate(); const FTreeCoordinate& coordNeighbors = distantNeighbors[idxNeigh]->getCoordinate();
const FComplexe* const transitionVector = &preM2LTransitions[indexM2LTransition(inLevel, const FComplexe* const transitionVector = &preM2LTransitions[indexM2LTransition(inLevel,
(coordCenter.getX() - coordNeighbors.getX()), (coordCenter.getX() - coordNeighbors.getX()),
(coordCenter.getY() - coordNeighbors.getY()), (coordCenter.getY() - coordNeighbors.getY()),
(coordCenter.getZ() - coordNeighbors.getZ()))]; (coordCenter.getZ() - coordNeighbors.getZ()))];
multipoleToLocal(pole->getLocal(), distantNeighbors[idxSize]->getMultipole(), transitionVector); multipoleToLocal(pole->getLocal(), distantNeighbors[idxNeigh]->getMultipole(), transitionVector);
...@@ -283,14 +295,83 @@ public: ...@@ -283,14 +295,83 @@ public:
/** Before Downward */ /** Before Downward */
void M2L(CellClass* const FRestrict , const CellClass* [189], FTreeCoordinate [189], const int , const int ) { void M2L(CellClass* const FRestrict local, const CellClass* distantNeighbors[189],
const FTreeCoordinate neighborsRelativePositions[189],
neighborsRelativePositions[idxNeigh].getX(),
neighborsRelativePositions[idxNeigh].getY(),
neighborsRelativePositions[idxNeigh].getZ())];
multipoleToLocal(local->getLocal(), distantNeighbors[idxNeigh]->getMultipole(), transitionVector);
/** After Downward */ /** After Downward */
void P2P(const MortonIndex , void P2P(const MortonIndex inCurrentIndex,
ContainerClass* const FRestrict , const ContainerClass* const FRestrict , ContainerClass* const FRestrict targets, const ContainerClass* const FRestrict /*sources*/,
ContainerClass* const [26], const FTreeCoordinate [26], const int ) { ContainerClass* const directNeighbors[26], const FTreeCoordinate neighborsRelativeOffset[26], const int size) {
{ // Compute interaction in this leaf
typename ContainerClass::BasicIterator iterTarget(*targets);
while( iterTarget.hasNotFinished() ){
// We copy the target particle to work with a particle in the heap
ParticleClass target( iterTarget.data() );
// For all particles after the current one
typename ContainerClass::BasicIterator iterSameBox = iterTarget;
iterSameBox.gotoNext();
while( iterSameBox.hasNotFinished() ){
directInteractionMutual(&target, &iterSameBox.data());
// Set data and progress
iterTarget.setData(target);
iterTarget.gotoNext();
{ // Compute interactions with other leaves
// For all the neigbors leaves
for(int idxDirectNeighbors = 0 ; idxDirectNeighbors < size ; ++idxDirectNeighbors){
// This box is not a real neighbor
if(neighborsRelativeOffset[idxDirectNeighbors].getX() || neighborsRelativeOffset[idxDirectNeighbors].getY()
|| neighborsRelativeOffset[idxDirectNeighbors].getZ() ){
// For all the particles in the other leaf
typename ContainerClass::BasicIterator iterSource(*directNeighbors[idxDirectNeighbors]);
while( iterSource.hasNotFinished() ){
directInteractionOffset(&target, iterSource.data(), neighborsRelativeOffset[idxDirectNeighbors]);
iterSource.gotoNext();
// This is a real neighbor, we do as usual
else if(inCurrentIndex < neighborsRelativeOffset[idxDirectNeighbors].getMortonIndex(treeHeight) ){
// For all particles in current leaf
directInteractionMutual(&target, &iterSource.data());
...@@ -832,6 +913,29 @@ public: ...@@ -832,6 +913,29 @@ public:
target->incForces( dx, dy, dz); target->incForces( dx, dy, dz);
target->incPotential( inv_distance * source.getPhysicalValue() ); target->incPotential( inv_distance * source.getPhysicalValue() );
/** P2P NO mutual interaction with an offset
* F = q * q' / r²
void directInteractionOffset(ParticleClass*const FRestrict target, const ParticleClass& source, const FTreeCoordinate& offset){
FReal dx = -(target->getPosition().getX() - source.getPosition().getX()) + FReal(offset.getX()) * boxWidth;
FReal dy = -(target->getPosition().getY() - source.getPosition().getY()) + FReal(offset.getY()) * boxWidth;
FReal dz = -(target->getPosition().getZ() - source.getPosition().getZ()) + FReal(offset.getZ()) * boxWidth;
FReal inv_square_distance = FReal(1.0) / (dx*dx + dy*dy + dz*dz);
FReal inv_distance = FMath::Sqrt(inv_square_distance);
inv_square_distance *= inv_distance;
inv_square_distance *= target->getPhysicalValue() * source.getPhysicalValue();
dx *= inv_square_distance;
dy *= inv_square_distance;
dz *= inv_square_distance;
