Commit 6acc2df2 authored by PIACIBELLO Cyrille's avatar PIACIBELLO Cyrille
typo and warning and names ...
parent 0bd6a4a7
...@@ -57,7 +57,7 @@ OPTION( ScalFMM_USE_SSE "Set to ON to compile with SSE support" ...@@ -57,7 +57,7 @@ OPTION( ScalFMM_USE_SSE "Set to ON to compile with SSE support"
OPTION( ScalFMM_USE_AVX "Set to ON to compile with AVX support" OFF ) OPTION( ScalFMM_USE_AVX "Set to ON to compile with AVX support" OFF )
OPTION( ScalFMM_USE_ASSERT "Set to ON to enable safe tests during execution" ON ) OPTION( ScalFMM_USE_ASSERT "Set to ON to enable safe tests during execution" ON )
OPTION( ScalFMM_USE_MIC_NATIVE "Set to ON to compile in native mode for MIC" OFF ) OPTION( ScalFMM_USE_MIC_NATIVE "Set to ON to compile in native mode for MIC" OFF )
OPTION( ScalFMM_BUILD_ONLY_LIB "Set to ON to compile ionly the lib (examples are not compiled) " OFF ) OPTION( ScalFMM_BUILD_ONLY_LIB "Set to ON to compile only the lib (examples are not compiled) " OFF )
# Set scalfmm to default libraries # Set scalfmm to default libraries
SET(SCALFMM_LIBRARIES "") SET(SCALFMM_LIBRARIES "")
SET(ScaLFMM_CXX_FLAGS "") SET(ScaLFMM_CXX_FLAGS "")
...@@ -93,11 +93,15 @@ class TestChebyshevMpiDirect : public FUTesterMpi<TestChebyshevMpiDirect>{ ...@@ -93,11 +93,15 @@ class TestChebyshevMpiDirect : public FUTesterMpi<TestChebyshevMpiDirect>{
FVector<TestParticle> finalParticles; FVector<TestParticle> finalParticles;
FLeafBalance balancer; FLeafBalance balancer;
OctreeClass tree(nbLevels,sizeOfSubLevel,loader.getBoxWidth(),loader.getCenterOfBox()); OctreeClass tree(nbLevels,sizeOfSubLevel,loader.getBoxWidth(),loader.getCenterOfBox());
FMpiTreeBuilder< TestParticle >::ArrayToTree(app.global(), particles, loader.getMyNumberOfParticles(), // FMpiTreeBuilder< TestParticle >::ArrayToTree(app.global(), particles, loader.getMyNumberOfParticles(),
// tree.getBoxCenter(),
// tree.getBoxWidth(),
// tree.getHeight(), &finalParticles,&balancer);
FMpiTreeBuilder< TestParticle >::DistributeArrayToContainer(app.global(),particles,
tree.getBoxCenter(), tree.getBoxCenter(),
tree.getBoxWidth(), tree.getBoxWidth(),tree.getHeight(),
tree.getHeight(), &finalParticles,&balancer); &finalParticles, &balancer);
for(int idx = 0 ; idx < finalParticles.getSize(); ++idx){ for(int idx = 0 ; idx < finalParticles.getSize(); ++idx){
tree.insert(finalParticles[idx].position,int(finalParticles[idx].index),finalParticles[idx].physicalValue); tree.insert(finalParticles[idx].position,int(finalParticles[idx].index),finalParticles[idx].physicalValue);
