Commit 649e4168 authored by Florent Pruvost's avatar Florent Pruvost
add detection of libeigen_blas as a blas lib
parent 8ad0feab
...@@ -43,9 +43,12 @@ ...@@ -43,9 +43,12 @@
### List of vendors (BLA_VENDOR) valid in this module ### List of vendors (BLA_VENDOR) valid in this module
########## List of vendors (BLA_VENDOR) valid in this module ########## List of vendors (BLA_VENDOR) valid in this module
## Goto,ATLAS PhiPACK,CXML,DXML,SunPerf,SCSL,SGIMATH,IBMESSL,Intel10_32 (intel mkl v10 32 bit),Intel10_64lp (intel mkl v10 64 bit,lp thread model, lp64 model), ## Open (for OpenBlas), Eigen (for EigenBlas), Goto, ATLAS PhiPACK,
##  CXML, DXML, SunPerf, SCSL, SGIMATH, IBMESSL,
## Intel10_32 (intel mkl v10 32 bit), Intel10_64lp (intel mkl v10 64 bit,lp thread model, lp64 model),
## Intel10_64lp_seq (intel mkl v10 64 bit,sequential code, lp64 model), ## Intel10_64lp_seq (intel mkl v10 64 bit,sequential code, lp64 model),
## Intel( older versions of mkl 32 and 64 bit), ACML,ACML_MP,ACML_GPU,Apple, NAS, Generic ## Intel( older versions of mkl 32 and 64 bit),
##  ACML, ACML_MP, ACML_GPU, Apple, NAS, Generic
# C/CXX should be enabled to use Intel mkl # C/CXX should be enabled to use Intel mkl
# We handle different modes to find the dependency # We handle different modes to find the dependency
...@@ -719,6 +722,7 @@ if (BLA_VENDOR STREQUAL "Goto" OR BLA_VENDOR STREQUAL "All") ...@@ -719,6 +722,7 @@ if (BLA_VENDOR STREQUAL "Goto" OR BLA_VENDOR STREQUAL "All")
endif (BLA_VENDOR STREQUAL "Goto" OR BLA_VENDOR STREQUAL "All") endif (BLA_VENDOR STREQUAL "Goto" OR BLA_VENDOR STREQUAL "All")
# OpenBlas
if (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All")
if(NOT BLAS_LIBRARIES) if(NOT BLAS_LIBRARIES)
...@@ -736,6 +740,36 @@ if (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All") ...@@ -736,6 +740,36 @@ if (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All")
endif (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All") endif (BLA_VENDOR STREQUAL "Open" OR BLA_VENDOR STREQUAL "All")
# EigenBlas
if (BLA_VENDOR STREQUAL "Eigen" OR BLA_VENDOR STREQUAL "All")
# eigenblas (http://eigen.tuxfamily.org/index.php?title=Main_Page)
check_fortran_libraries(
BLAS_LIBRARIES
BLAS
sgemm
"eigen_blas"
endif()
BLAS_LIBRARIES
BLAS
sgemm
"eigen_blas_static"
endif()
endif (BLA_VENDOR STREQUAL "Eigen" OR BLA_VENDOR STREQUAL "All")
if (BLA_VENDOR STREQUAL "ATLAS" OR BLA_VENDOR STREQUAL "All") if (BLA_VENDOR STREQUAL "ATLAS" OR BLA_VENDOR STREQUAL "All")
...@@ -43,7 +43,7 @@ ...@@ -43,7 +43,7 @@
# add a cache variable to let the user specify the BLAS vendor # add a cache variable to let the user specify the BLAS vendor
set(BLA_VENDOR "" CACHE STRING "list of possible BLAS vendor: set(BLA_VENDOR "" CACHE STRING "list of possible BLAS vendor:
Goto, ATLAS PhiPACK, CXML, DXML, SunPerf, SCSL, SGIMATH, IBMESSL, Open, Eigen, Goto, ATLAS PhiPACK, CXML, DXML, SunPerf, SCSL, SGIMATH, IBMESSL,
Intel10_32 (intel mkl v10 32 bit), Intel10_32 (intel mkl v10 32 bit),
Intel10_64lp (intel mkl v10 64 bit, lp thread model, lp64 model), Intel10_64lp (intel mkl v10 64 bit, lp thread model, lp64 model),
Intel10_64lp_seq (intel mkl v10 64 bit, sequential code, lp64 model), Intel10_64lp_seq (intel mkl v10 64 bit, sequential code, lp64 model),
