Commit 63aeb8ab authored by COULAUD Olivier's avatar COULAUD Olivier
Fix problem with Cpack
parent 48c145c6
......@@ -57,6 +57,7 @@ OPTION( ScalFMM_USE_AVX "Set to ON to compile with AVX support"
OPTION( ScalFMM_USE_ASSERT "Set to ON to enable safe tests during execution" ON )
OPTION( ScalFMM_USE_MIC_NATIVE "Set to ON to compile in native mode for MIC" OFF )
OPTION( ScalFMM_BUILD_ONLY_LIB "Set to ON to compile only the lib (examples are not compiled) " OFF )
OPTION( ScalFMM_ONLY_DEVEL "Set to ON to compile Development tools (only scalfmm team)" OFF )
# Set scalfmm to default libraries
SET(SCALFMM_LIBRARIES "")
SET(ScaLFMM_CXX_FLAGS "")
......@@ -168,7 +169,6 @@ endif(ScalFMM_ATTACHE_SOURCE)
if( ScalFMM_USE_BLAS )
OPTION( ScalFMM_USE_MKL_AS_BLAS "Set to ON to use MKL CBLAS" OFF )
if( ScalFMM_USE_MKL_AS_BLAS )
MESSAGE(STATUS "FFFFFFFFFFFFFFFFF " ${CMAKE_CXX_COMPILER_ID} )
IF(CMAKE_CXX_COMPILER_ID STREQUAL "Intel" )
SET(BLAS_LIBRARIES "-mkl=sequential" CACHE STRING "Set your MKL flags")
else()
......@@ -338,7 +338,7 @@ endif()
# Build tools (Internal use) #
# Build - UTIL
# Build - UTILs
if( ScalFMM_ONLY_DEVEL )
#if( NOT ScalFMM_BUILD_ONLY_LIB )
add_subdirectory(Utils)
......@@ -416,7 +416,6 @@ INSTALL(FILES
# build a CPack driven installer package #
INCLUDE(CPack)
# Use git commit number as CPACK_PACKAGE_VERSION_PATCH
set(CPACK_PACKAGE_VERSION_PATCH 0)
......@@ -426,17 +425,23 @@ execute_process(
RESULT_VARIABLE RET
ERROR_QUIET OUTPUT_STRIP_TRAILING_WHITESPACE
# STRING_TRIM(PATCH1 PATCH)
#STRING_TRIM(PATCH1 PATCH)
SET(CPACK_INCLUDE_TOPLEVEL_DIRECTORY "ON")
set (CPACK_RESOURCE_FILE_LICENSE "${CMAKE_CURRENT_SOURCE_DIR}/Licence.txt")
SET(CPACK_PACKAGE_VERSION_MAJOR "${ScalFMM_MAJOR_VERSION}")
SET(CPACK_PACKAGE_VERSION_NINOR "${ScalFMM_MINOR_VERSION}")
SET(CPACK_PACKAGE_VERSION_MINOR "${ScalFMM_MINOR_VERSION}")
SET(PACK_PACKAGE_VERSION "${ScalFMM_MAJOR_VERSION}.${ScalFMM_MINOR_VERSION}-${CPACK_PACKAGE_VERSION_PATCH}")
SET(CPACK_SOURCE_GENERATOR "TGZ")
SET(CPACK_SOURCE_PACKAGE_FILE_NAME "ScalFMM-${ScalFMM_MAJOR_VERSION}.${ScalFMM_MINOR_VERSION}-${CPACK_PACKAGE_VERSION_PATCH}")
SET(CPACK_SOURCE_IGNORE_FILES "\\\\.git;.DS_Store;.*~;/*.aux;/*.idx;/*.log;/*.out;/*.toc;/*.ilg;/*.ind;scalfmm.pro*;org.eclipse.core.resources.prefs;.cproject;.project")
LIST(APPEND CPACK_SOURCE_IGNORE_FILES "${CMAKE_BINARY_DIR};${CMAKE_SOURCE_DIR}/Utils/;Notes;Deprecated;Build*,noDist" )
LIST(APPEND CPACK_SOURCE_IGNORE_FILES "${CMAKE_BINARY_DIR};${CMAKE_SOURCE_DIR}/Utils/;Notes;Deprecated;Build*;noDist;Bench;ToRemove;Olivier;tages;Uniform;GroupTree;Adaptive;testUnif*;/*Lagrange*")
#LIST(APPEND CPACK_SOURCE_IGNORE_FILES "Stages;Uniform;Adaptive;testUnif*;*Lagrange*" )
INCLUDE(CPack)
# PRINT MESSAGES #
......@@ -47,7 +47,7 @@
#include "Kernels/Interpolation/FInterpMatrixKernel.hpp"
#include "Kernels/Uniform/FUnifCell.hpp"
#include "Adaptive/FAdaptUnifKernel.hpp"
#include "Adaptive/FAdaptTools.hpp"
//#include "Adaptive/FAdaptTools.hpp"
#include "Core/FFmmAlgorithm.hpp"
