@@ -65,9 +69,9 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
option( SCALFMM_USE_MEM_STATS "Set to ON to profile memory" OFF )
option( SCALFMM_ATTACHE_SOURCE "Set to ON to compile with -g" OFF )
option( SCALFMM_USE_ADDONS "Set to ON to compile add ons" OFF )
option( SCALFMM_USE_SSE "Set to ON to compile with SSE support (and use intrinsec SSE P2P)" ON)
CMAKE_DEPENDENT_OPTION( SCALFMM_USE_SSE "Set to ON to compile with SSE support (and use intrinsec SSE P2P)" ON "CPUOPTION_SSE3;NOT CPUOPTION_AVX;NOT CPUOPTION_AVX2" OFF)
option( SCALFMM_USE_AVX "Set to ON to compile with AVX support (and use intrinsec AVX P2P)" OFF )
CMAKE_DEPENDENT_OPTION( SCALFMM_USE_AVX "Set to ON to compile with AVX support (and use intrinsec AVX P2P)" ON "CPUOPTION_AVX; NOT CPUOPTION_AVX2" OFF )
option( SCALFMM_USE_AVX2 "Set to ON to compile with AVX support (and use intrinsec AVXZ P2P)" OFF )
CMAKE_DEPENDENT_OPTION( SCALFMM_USE_AVX2 "Set to ON to compile with AVX support (and use intrinsec AVXZ P2P)" ON "CPUOPTION_AVX2" OFF )
option( SCALFMM_USE_ASSERT "Set to ON to enable safe tests during execution" ON )
option( SCALFMM_USE_MIC_NATIVE "Set to ON to compile in native mode for MIC" OFF )
option( SCALFMM_ONLY_DEVEL "Set to ON to compile Development tools (only scalfmm team)" ON )
