Commit 5a0b2e1c authored by PRUVOST Florent's avatar PRUVOST Florent
remove cppcheck flag --std=c++14 which does not seem to be an cppcheck valid option
parent f3b658be
...@@ -24,8 +24,8 @@ export SOURCES_TO_ANALYZE="Src Examples Tests UTests" ...@@ -24,8 +24,8 @@ export SOURCES_TO_ANALYZE="Src Examples Tests UTests"
# commented for now because too long # commented for now because too long
export CPPCHECK_INCLUDES="-IBuild/Src -ISrc -IContribs" export CPPCHECK_INCLUDES="-IBuild/Src -ISrc -IContribs"
export SOURCES_TO_ANALYZE="Src Examples Tests UTests" export SOURCES_TO_ANALYZE="Src Examples Tests UTests"
export CPPCHECK_UNDEF="-USCALFMM_USE_AVX -USCALFMM_USE_AVX2 -USCALFMM_USE_SSE -USCALFMM_USE_EZTRACE -U__AVXPE_INTEL_COMPILER -U__INTEL_COMPILER -U__MIC__ -U__SSEPE_INTEL_COMPILER -U__SSSE3__ -U__SSSE4_1__ -U_WIN32 -Umin" export CPPCHECK_UNDEF="-USCALFMM_USE_AVX -USCALFMM_USE_AVX2 -USCALFMM_USE_SSE -USCALFMM_USE_EZTRACE -U__AVXPE_INTEL_COMPILER -U__INTEL_COMPILER -U__MIC__ -U__SSEPE_INTEL_COMPILER -U__SSSE3__ -U__SSSE4_1__ -U_WIN32 -Uming"
cppcheck -v -f --language=c++ --std=c++14 --platform=unix64 --enable=all --xml --xml-version=2 --suppress=missingIncludeSystem ${CPPCHECK_UNDEF} ${CPPCHECK_INCLUDES} ${SOURCES_TO_ANALYZE} 2> scalfmm-cppcheck.xml cppcheck -v -f --language=c++ --platform=unix64 --enable=all --xml --xml-version=2 --suppress=missingIncludeSystem ${CPPCHECK_UNDEF} ${CPPCHECK_INCLUDES} ${SOURCES_TO_ANALYZE} 2> scalfmm-cppcheck.xml
# run rats analysis # run rats analysis
rats -w 3 --xml ${SOURCES_TO_ANALYZE} > scalfmm-rats.xml rats -w 3 --xml ${SOURCES_TO_ANALYZE} > scalfmm-rats.xml
