Commit 521c328a authored by COULAUD Olivier's avatar COULAUD Olivier
Fix segmentation fault with Intel and MscOS X.
parent c51c84a5
...@@ -94,8 +94,12 @@ SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -std=c++11 -fpic -Wall ") ...@@ -94,8 +94,12 @@ SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -std=c++11 -fpic -Wall ")
if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel") if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel")
# INTEL # INTEL
SET(AVX_FLAGS "-mavx") IF (APPLE)
SET(SSE_FLAGS "-axSSE4.2") SET(SSE_FLAGS "-msse4 -mfpmath=sse") # -mtune=native -march=native
ELSE(APPLE)
ENDIF(APPLE)
#-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ") #-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ")
else() else()
# NOT INTEL # NOT INTEL
