Commit 4d112c8c authored by Florent Pruvost's avatar Florent Pruvost
add libs z, m and rt for scotch function test only if discovered on the system
parent c9a00713
...@@ -264,10 +264,21 @@ if(PTSCOTCH_LIBRARIES) ...@@ -264,10 +264,21 @@ if(PTSCOTCH_LIBRARIES)
if(CMAKE_THREAD_LIBS_INIT) if(CMAKE_THREAD_LIBS_INIT)
list(APPEND REQUIRED_LIBS "${CMAKE_THREAD_LIBS_INIT}") list(APPEND REQUIRED_LIBS "${CMAKE_THREAD_LIBS_INIT}")
endif() endif()
if(UNIX OR WIN32) set(Z_LIBRARY "Z_LIBRARY-NOTFOUND")
find_library(Z_LIBRARY NAMES z)
if(Z_LIBRARY)
list(APPEND REQUIRED_LIBS "-lz")
endif()
set(M_LIBRARY "M_LIBRARY-NOTFOUND")
find_library(M_LIBRARY NAMES m)
if(M_LIBRARY)
list(APPEND REQUIRED_LIBS "-lm") list(APPEND REQUIRED_LIBS "-lm")
endif() endif()
list(APPEND REQUIRED_LIBS "-lz -lrt") set(RT_LIBRARY "RT_LIBRARY-NOTFOUND")
find_library(RT_LIBRARY NAMES rt)
if(RT_LIBRARY)
list(APPEND REQUIRED_LIBS "-lrt")
endif()
# set required libraries for link # set required libraries for link
set(CMAKE_REQUIRED_INCLUDES "${REQUIRED_INCDIRS}") set(CMAKE_REQUIRED_INCLUDES "${REQUIRED_INCDIRS}")
...@@ -233,10 +233,21 @@ if(SCOTCH_LIBRARIES) ...@@ -233,10 +233,21 @@ if(SCOTCH_LIBRARIES)
endif() endif()
if(Z_LIBRARY)
endif()
if(M_LIBRARY)
endif() endif()
if(RT_LIBRARY)
endif()
