Commit 46063a91 authored by berenger-bramas's avatar berenger-bramas
A git svn problem.
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/scalfmm/scalfmm/trunk@357 2616d619-271b-44dc-8df4-d4a8f33a7222
parent db549250
...@@ -20,7 +20,7 @@ ...@@ -20,7 +20,7 @@
#include "../Utils/FGlobal.hpp" #include "../Utils/FGlobal.hpp"
// To get memcpy // To get memcpy
#include <string.h> #include <cstring>
* @author Berenger Bramas (berenger.bramas@inria.fr) * @author Berenger Bramas (berenger.bramas@inria.fr)
...@@ -17,7 +17,7 @@ ...@@ -17,7 +17,7 @@
#define FEXTENDFMBCELL_HPP #define FEXTENDFMBCELL_HPP
#include "../Utils/FComplexe.hpp" #include "../Utils/FComplexe.hpp"
...@@ -19,6 +19,7 @@ ...@@ -19,6 +19,7 @@
#include <cstring> #include <cstring>
#include <iostream>
#include "FGlobal.hpp" #include "FGlobal.hpp"
...@@ -259,24 +260,22 @@ public: ...@@ -259,24 +260,22 @@ public:
return F3DPosition(inPosition.x + inOther.x, inPosition.y + inOther.y, inPosition.z + inOther.z); return F3DPosition(inPosition.x + inOther.x, inPosition.y + inOther.y, inPosition.z + inOther.z);
* Operator stream F3DPosition to std::ostream * Operator stream F3DPosition to std::ostream
* This can be used to simply write out a position * This can be used to simply write out a position
* @param[in,out] output where to write the position * @param[in,out] output where to write the position
* @param[in] inPosition the position to write out * @param[in] inPosition the position to write out
* @return the output for multiple << operators * @return the output for multiple << operators
friend std::ostream& operator<<(std::ostream& output, const F3DPosition& inPosition) friend std::ostream& operator<<(std::ostream& output, const F3DPosition& inPosition){
{ output << "(" << inPosition.getX() << ", " << inPosition.getY() << ", " << inPosition.getZ() <<")";
output << "(" << inPosition.getX() << ", " << inPosition.getY() << ", " << inPosition.getZ() <<")"; return output; // for multiple << operators.
return output; // for multiple << operators. }
#endif //F3DPOSITION_HPP #endif //F3DPOSITION_HPP
...@@ -18,7 +18,7 @@ ...@@ -18,7 +18,7 @@
#include <sstream> #include <sstream>
#include <iostream> #include <iostream>
/** This file proposes some methods /** This file proposes some methods
* to work with user input parameters. * to work with user input parameters.
Supports Markdown
