Commit 455e32e9 authored by BRAMAS Berenger's avatar BRAMAS Berenger
Typo in cheb block when using omp4
parent 910582b5
...@@ -77,8 +77,8 @@ int main(int argc, char* argv[]){ ...@@ -77,8 +77,8 @@ int main(int argc, char* argv[]){
typedef FChebSymKernel<GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass; typedef FChebSymKernel<GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass;
// Set the number of threads // Set the number of threads
omp_set_num_threads(FParameters::getValue(argc,argv,FParameterDefinitions::NbThreads.options, omp_get_max_threads())); omp_set_num_threads(FParameters::getValue(argc,argv,FParameterDefinitions::NbThreads.options, omp_get_max_threads()));
typedef FGroupTaskDepAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass typedef FGroupTaskDepAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass,
GroupCellSymbClass, GroupCellUpClass, GroupCellDownClass,, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm; GroupCellSymbClass, GroupCellUpClass, GroupCellDownClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm;
#else #else
//typedef FGroupSeqAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm; //typedef FGroupSeqAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm;
Supports Markdown
