Commit 44d89c82 authored by COULAUD Olivier's avatar COULAUD Olivier
Set automatic choice for OMP4
parent 6831e546
...@@ -108,7 +108,11 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -108,7 +108,11 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
option( OPENMP_SUPPORT_COMMUTE "Set to ON to let tasks commute (KSTAR/StarPU compiler only)" OFF ) option( OPENMP_SUPPORT_COMMUTE "Set to ON to let tasks commute (KSTAR/StarPU compiler only)" OFF )
option( OPENMP_SUPPORT_PRIORITY "Set to ON to enable tasks priority (KSTAR/StarPU compiler only)" OFF ) option( OPENMP_SUPPORT_PRIORITY "Set to ON to enable tasks priority (KSTAR/StarPU compiler only)" OFF )
option( OPENMP_SUPPORT_TASK_NAME "Set to ON to enable a taskname clause for tasks (KSTAR/StarPU compiler only)" OFF ) option( OPENMP_SUPPORT_TASK_NAME "Set to ON to enable a taskname clause for tasks (KSTAR/StarPU compiler only)" OFF )
option( SCALFMM_DISABLE_NATIVE_OMP4 "Set to ON to disable the gcc/intel omp4" OFF ) if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel")
else()
option( SCALFMM_DISABLE_NATIVE_OMP4 "Set to ON to disable the gcc/intel omp4" ON )
endif()
option( SCALFMM_TIME_OMPTASKS "Set to ON to time omp4 tasks and generate output file" OFF ) option( SCALFMM_TIME_OMPTASKS "Set to ON to time omp4 tasks and generate output file" OFF )
option( SCALFMM_SIMGRID_NODATA "Set to ON to avoid the allocation of numerical parts in the group tree" OFF ) option( SCALFMM_SIMGRID_NODATA "Set to ON to avoid the allocation of numerical parts in the group tree" OFF )
option( SCALFMM_SIMGRID_TASKNAMEPARAMS "Set to ON to have verbose information in the task name" OFF ) option( SCALFMM_SIMGRID_TASKNAMEPARAMS "Set to ON to have verbose information in the task name" OFF )
