Commit 44617b5f authored by Quentin Khan's avatar Quentin Khan
Root CMakeLists.txt: Correct build-breaking bug introduced by 65a7eb10
65a7eb10 introduced a dependent option
in build process. It is not enabled by default on all CMake installations
and requires a :
INCLUDE(CMakeDependentOption)
parent 117647fc
...@@ -21,6 +21,8 @@ endif(insource) ...@@ -21,6 +21,8 @@ endif(insource)
set(SCALFMM_CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/CMakeModules) set(SCALFMM_CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/CMakeModules)
# Adds the CMAKE_DEPENDENT_OPTION command
# Version Number # Version Number
...@@ -305,7 +307,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -305,7 +307,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
# FFT option # FFT option
CMAKE_DEPENDENT_OPTION(SCALFMM_USE_MKL_AS_FFTW "Set to ON to use MKL FFTW" ON "SCALFMM_USE_FFT;SCALFMM_USE_MKL_AS_BLAS" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_USE_MKL_AS_FFTW "Set to ON to use MKL FFTW" ON "SCALFMM_USE_FFT;SCALFMM_USE_MKL_AS_BLAS" OFF )
if( SCALFMM_USE_FFT ) if( SCALFMM_USE_FFT )
message(STATUS "SCALFMM USE FFT Configure:") message(STATUS "SCALFMM USE FFT Configure:")
