Commit 341fdb57 authored by COULAUD Olivier's avatar COULAUD Olivier
Merge branch 'master' of git+ssh://scm.gforge.inria.fr//gitroot/scalfmm/scalfmm
# By piacibel (3) and bramas (2)
# Via piacibel
* 'master' of git+ssh://scm.gforge.inria.fr//gitroot/scalfmm/scalfmm:
  finals update from MPI/Thread to MPI/Thread Periodic
  Logs updated
  Update neighbors computation in C kernel api
  Move thread kernel inside the task to ensure correct value
  Changes of Mpi version moved to PeriodiqueMpi version (except P2P)
parents 8e713246 4eee45b0
...@@ -94,17 +94,17 @@ void Scalfmm_execute_kernel(Scalfmm_Handle handle, struct Scalfmm_Kernel_Descrip ...@@ -94,17 +94,17 @@ void Scalfmm_execute_kernel(Scalfmm_Handle handle, struct Scalfmm_Kernel_Descrip
//< This function fill the childFullPosition[3] with [0;1] to know the position of a child relatively to //< This function fill the childFullPosition[3] with [0;1] to know the position of a child relatively to
//< its position from its parent //< its position from its parent
inline void Scalfmm_utils_parentChildPosition(int childPosition, int* childFullPosition){ inline void Scalfmm_utils_parentChildPosition(int childPosition, int* childFullPosition){
childFullPosition[0] = childPosition%2; childFullPosition[2] = (childPosition%2 ? 1 : -1);
childFullPosition[1] = (childPosition/2)%2; childFullPosition[1] = ((childPosition/2)%2 ? 1 : -1);
childFullPosition[2] = (childPosition/4)%2; childFullPosition[0] = ((childPosition/4)%2 ? 1 : -1);
//< This function fill the childFullPosition[3] with [-3;3] to know the position of a interaction //< This function fill the childFullPosition[3] with [-3;3] to know the position of a interaction
//< cell relatively to its position from the target //< cell relatively to its position from the target
inline void Scalfmm_utils_interactionPosition(int interactionPosition, int* srcPosition){ inline void Scalfmm_utils_interactionPosition(int interactionPosition, int* srcPosition){
srcPosition[0] = interactionPosition%7 - 3; srcPosition[2] = interactionPosition%7 - 3;
srcPosition[1] = (interactionPosition/7)%7 - 3; srcPosition[1] = (interactionPosition/7)%7 - 3;
srcPosition[2] = (interactionPosition/49)%7 - 3; srcPosition[0] = (interactionPosition/49)%7 - 3;
#endif // CKERNELAPI_H #endif // CKERNELAPI_H
This diff is collapsed.
