Commit 33bfb23b authored by COULAUD Olivier's avatar COULAUD Olivier
Fix typo in doc
Protect Utils repository
parent f89b1bb6
...@@ -137,7 +137,6 @@ else() ...@@ -137,7 +137,6 @@ else()
IF(CMAKE_CXX_COMPILER_ID STREQUAL "Intel") IF(CMAKE_CXX_COMPILER_ID STREQUAL "Intel")
SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -ip -no-prec-div -no-prec-sqrt") SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -ip -no-prec-div -no-prec-sqrt")
ENDIF() ENDIF()
# Compile optimization # Compile optimization
IF( APPLE ) IF( APPLE )
SET(SCALFMM_FLAGS_OPTI_RELEASE "-m64 -funroll-loops" CACHE STRING "Set your optimization flags for release mode.") SET(SCALFMM_FLAGS_OPTI_RELEASE "-m64 -funroll-loops" CACHE STRING "Set your optimization flags for release mode.")
...@@ -339,8 +338,9 @@ endif() ...@@ -339,8 +338,9 @@ endif()
# Build tools (Internal use) # # Build tools (Internal use) #
# Build - Tests # Build - UTIL
if( NOT ScalFMM_BUILD_ONLY_LIB ) if( ScalFMM_ONLY_DEVEL )
#if( NOT ScalFMM_BUILD_ONLY_LIB )
add_subdirectory(Utils) add_subdirectory(Utils)
endif() endif()
...@@ -50,7 +50,7 @@ ...@@ -50,7 +50,7 @@
* <li> ScalFMM_ATTACHE_SOURCE : to build with -g </li> * <li> ScalFMM_ATTACHE_SOURCE : to build with -g </li>
* <li> SScalFMM_BUILD_TESTS : to build the text and the examples </li> * <li> SScalFMM_BUILD_TESTS : to build the text and the examples </li>
* <li> ScalFMM_BUILD_UTESTS : to build the unit tests </li> * <li> ScalFMM_BUILD_UTESTS : to build the unit tests </li>
* <li> SScalFMM_USE_ADDONS : to activate add ons </li> * <li> ScalFMM_USE_ADDONS : to activate add ons </li>
* <ul> * <ul>
* <li> SCALFMM_ADDON_FMMAPI : to build Fmm Api </li> * <li> SCALFMM_ADDON_FMMAPI : to build Fmm Api </li>
* </ul> * </ul>
