Commit 326878be authored by PIACIBELLO Cyrille's avatar PIACIBELLO Cyrille
Derivative operator is right, P2M is supposed to be right to
parent a36acae2
...@@ -89,8 +89,9 @@ private: ...@@ -89,8 +89,9 @@ private:
FPoint getCellCenter(const FTreeCoordinate coordinate, int inLevel) FPoint getCellCenter(const FTreeCoordinate coordinate, int inLevel)
//Set the boxes width needed //Set the boxes width needed
FReal widthAtCurrentLevel = widthAtLeafLevel*FReal(1 << (treeHeight-inLevel)); FReal widthAtCurrentLevel = widthAtLeafLevel*FReal(1 << (treeHeight-(inLevel+1)));
FReal widthAtCurrentLevelDiv2 = widthAtCurrentLevel/FReal(2); FReal widthAtCurrentLevelDiv2 = widthAtCurrentLevel/FReal(2);
//Get the coordinate //Get the coordinate
...@@ -200,7 +201,9 @@ private: ...@@ -200,7 +201,9 @@ private:
* @todo METTRE les fonctions pour intialiser la recurrence. \f$x_i\f$ ?? \f$x_i\f$ ?? * @todo METTRE les fonctions pour intialiser la recurrence. \f$x_i\f$ ?? \f$x_i\f$ ??
* @todo LA formule ci-dessous n'utilise pas k! * @todo LA formule ci-dessous n'utilise pas k!
void initDerivative(const FPoint target, const FPoint src, FReal * tab) void initDerivative(const FPoint target, // Center of local cell
const FPoint src, // Center of distant cell
FReal * tab)
FReal dx = target.getX()-src.getX(); FReal dx = target.getX()-src.getX();
FReal dy = target.getY()-src.getY(); FReal dy = target.getY()-src.getY();
...@@ -222,11 +225,23 @@ private: ...@@ -222,11 +225,23 @@ private:
/** @brief Compute and store the derivative for a given tuple. /** @brief Compute and store the derivative for a given tuple.
* Derivative are used for the M2L
*\f[
* \Psi_{\mathbf{k}}^{c}\times \left [\left |\mathbf{k}\right |\times \left |
* \mathbf{x}_i-\mathbf{x}_c\right |^2 \times
* \frac{1}{\mathbf{k}!} \right ]\
* = (2\times \left |{\mathbf{k}}\right |-1)\times
* \sum_{j=0}^{3}\left [(x_{i_j}-x_{c_j})\times
* \Psi_{\mathbf{k}-e_j,i}^{c}\times \frac{1}{({\mathbf{k}}-e_j)!}\right ]\
* -(\left |\mathbf{k}\right |-1)\times \sum_{j=0}^{3}\left
* [\Psi_{\mathbf{k}-2\times e_j,i}^{c}\times \frac{1}{(\mathbf{k}-2\times e_j)!}\right]
* \f]
FReal computeDerivative(const int a, const int b, const int c, FReal computeDerivative(const int a, const int b, const int c, // Powers of derivatives
const FPoint target, const FPoint target, // Center of local cell
const FPoint src, const FPoint src, // Center of distant cell
FReal * yetComputed) FReal * yetComputed)
int idx = powerToIdx(a,b,c); int idx = powerToIdx(a,b,c);
...@@ -238,13 +253,12 @@ private: ...@@ -238,13 +253,12 @@ private:
FReal dz = target.getZ()-src.getZ(); FReal dz = target.getZ()-src.getZ();
FReal fct = fact3int(a,b,c);
FReal dist2 = dx*dx+dy*dy+dz*dz; FReal dist2 = dx*dx+dy*dy+dz*dz;
FReal temp_value = FReal(0.0); FReal temp_value = FReal(0.0);
int idxt; int idxt;
if(a > 0){ if(a > 0){
idxt = powerToIdx(a-1,b,c); idxt = powerToIdx(a-1,b,c);
temp_value += ((FReal)(2*(a+b+c)-1))*dx*yetComputed[idxt]*FReal(a); temp_value += (FReal(2*(a+b+c)-1))*dx*yetComputed[idxt]*FReal(a);
if(a > 1){ if(a > 1){
idxt = powerToIdx(a-2,b,c); idxt = powerToIdx(a-2,b,c);
temp_value -= FReal(a+b+c-1)*yetComputed[idxt]*FReal(a*(a-1)); temp_value -= FReal(a+b+c-1)*yetComputed[idxt]*FReal(a*(a-1));
...@@ -414,7 +428,7 @@ public: ...@@ -414,7 +428,7 @@ public:
FReal dz = 0.0; FReal dz = 0.0;
//Center point of parent cell //Center point of parent cell
const FPoint& cellCenter = getLeafCenter(pole->getCoordinate()); const FPoint& cellCenter = getLeafCenter(pole->getCoordinate());
printf("M2M :: pole : X: %f, Y: %f, Z:%f\n",cellCenter.getX(),cellCenter.getY(),cellCenter.getZ()); printf("M2M :: pole_target : X: %f, Y: %f, Z:%f\n",cellCenter.getX(),cellCenter.getY(),cellCenter.getZ());
FReal * mult = pole->getMultipole(); FReal * mult = pole->getMultipole();
FMemUtils::memset(pole,0,SizeVector*FReal(0)); FMemUtils::memset(pole,0,SizeVector*FReal(0));
...@@ -486,17 +500,17 @@ public: ...@@ -486,17 +500,17 @@ public:
*Where \f$x_c^{src}\f$ is the centre of the cell where the multiplole are considered,\f$x_c^{target}\f$ is the centre of the current celle. The celle where we compute the local expansion. *Where \f$x_c^{src}\f$ is the centre of the cell where the multiplole are considered,\f$x_c^{target}\f$ is the centre of the current celle. The celle where we compute the local expansion.
void M2L(CellClass* const FRestrict local, void M2L(CellClass* const FRestrict local, // Target cell
const CellClass* distantNeighbors[343], const CellClass* distantNeighbors[343], // Sources to be read
const int /*size*/, const int /*inLevel*/) const int /*size*/, const int inLevel)
printf("M2L\n"); printf("M2L\n");
//Iteration over distantNeighbors //Iteration over distantNeighbors
int idxNeigh; int idxNeigh;
// WARNING, won't work at upper level than leaf. // WARNING, won't work at upper level than leaf.
FPoint locCenter = getLeafCenter(local->getCoordinate()); FPoint locCenter = getCellCenter(local->getCoordinate(),inLevel);
printf("M2M :: pole_target : X: %f, Y: %f, Z:%f\n",locCenter.getX(),locCenter.getY(),locCenter.getZ());
FReal * iterLocal = local->getLocal(); FReal * iterLocal = local->getLocal();
FMemUtils::memset(iterLocal,0,SizeVector*sizeof(FReal(0))); FMemUtils::memset(iterLocal,0,SizeVector*sizeof(FReal(0)));
...@@ -505,18 +519,20 @@ public: ...@@ -505,18 +519,20 @@ public:
//Need to test if current neighbor is one of the interaction list //Need to test if current neighbor is one of the interaction list
if(distantNeighbors[idxNeigh]){ if(distantNeighbors[idxNeigh]){
//Derivatives are computed iteratively //Derivatives are computed iteratively
FReal yetComputed[(2*P+1)*(P+1)*(2*P+3)/3]; int sizeDerivative = (2*P+1)*(P+1)*(2*P+3)/3;
FMemUtils::memset(yetComputed,0,((2*P+1)*(P+1)*(2*P+3)/3)*sizeof(FReal(0))); FReal yetComputed[sizeDerivative];
FMemUtils::memset(yetComputed,0,sizeDerivative*sizeof(FReal(0)));
FPoint curDistCenter = getLeafCenter(distantNeighbors[idxNeigh]->getCoordinate()); FPoint curDistCenter = getCellCenter(distantNeighbors[idxNeigh]->getCoordinate(),inLevel);
initDerivative(curDistCenter, locCenter, yetComputed); printf("M2M :: pole_source : X: %f, Y: %f, Z:%f\n",curDistCenter.getX(),curDistCenter.getY(),curDistCenter.getZ());
initDerivative(locCenter, curDistCenter, yetComputed); //(target,source,yetComputed)
//Iteration over Multipole / Local //Iteration over Multipole / Local
int al=0,bl=0,cl=0; //For local array int al=0,bl=0,cl=0; //For local array
int am,bm,cm; //For distant array int am,bm,cm; //For distant array
int count=0;
//Iterating over local array : n //Iterating over local array : n
for(int i=0 ; i< SizeVector ; i++){ for(int i=0 ; i< SizeVector ; i++){
FReal fctl = fact3int(al,bl,cl); FReal fctl = fact3int(al,bl,cl);
...@@ -531,9 +547,9 @@ public: ...@@ -531,9 +547,9 @@ public:
// Loc(al,bl,cl) = sum_ Psi* M[am,bm,cm] * N(al,bl,cl)/(al,bl,cl)! // Loc(al,bl,cl) = sum_ Psi* M[am,bm,cm] * N(al,bl,cl)/(al,bl,cl)!
for(int j = 0 ; j < SizeVector ; ++j){ //corresponding powers am,bm,cm for(int j = 0 ; j < SizeVector ; ++j){ //corresponding powers am,bm,cm
//psi is the derivative of 1/R,al+am,bl+bm,cl+cm. //psi is the derivative of 1/R,al+am,bl+bm,cl+cm.
psi = computeDerivative(al+am,bl+bm,cl+cm,curDistCenter,locCenter,yetComputed); psi = computeDerivative(al+am,bl+bm,cl+cm,curDistCenter,locCenter,yetComputed); //(order of derivative, target, source, yetComputed)
tmp += psi*multipole[j]; tmp += psi*multipole[j];
++count; //++count;
//printf("count : %d, al+am = %d, bl+bm=%d, cl+cm=%d\n",count,al+am,bl+bm,cl+cm); //printf("count : %d, al+am = %d, bl+bm=%d, cl+cm=%d\n",count,al+am,bl+bm,cl+cm);
//updating a,b,c //updating a,b,c
incPowers(&am,&bm,&cm); incPowers(&am,&bm,&cm);
...@@ -544,10 +560,10 @@ public: ...@@ -544,10 +560,10 @@ public:
// For Debugging .......................................................... // For Debugging ..........................................................
int x=0,y=0,z=0; int x=0,y=0,z=0;
FReal tot = FReal(0); FReal tot = FReal(0);
for(int dby=0 ; dby<SizeVector ; dby++) for(int dby=0 ; dby<sizeDerivative ; dby++)
tot+=yetComputed[dby]; tot+=yetComputed[dby];
printf("M2L :: cell %f, %d,%d,%d ==> %f\n",curDistCenter.getX(),x,y,z,iterLocal[dby]); printf("M2L :: source %f, %d,%d,%d ==> %f\n",curDistCenter.getX(),x,y,z,yetComputed[dby]);
incPowers(&x,&y,&z); incPowers(&x,&y,&z);
printf("tot : %f\n",tot); printf("tot : %f\n",tot);
