Commit 2e1a4c1f authored by Martin Khannouz's avatar Martin Khannouz Committed by Berenger Bramas
Modify test a bit.
So we get average time of executing and test to check if the result is
good.
parent 18612f99
...@@ -76,7 +76,6 @@ void sortParticle(FPoint<FReal> * allParticlesToSort, int treeHeight, int groupS ...@@ -76,7 +76,6 @@ void sortParticle(FPoint<FReal> * allParticlesToSort, int treeHeight, int groupS
void createNodeRepartition(std::vector<MortonIndex> distributedMortonIndex, std::vector<std::vector<std::vector<MortonIndex>>>& nodeRepartition, int nproc, int treeHeight); void createNodeRepartition(std::vector<MortonIndex> distributedMortonIndex, std::vector<std::vector<std::vector<MortonIndex>>>& nodeRepartition, int nproc, int treeHeight);
int main(int argc, char* argv[]){ int main(int argc, char* argv[]){
setenv("STARPU_NCPU","1",1);
const FParameterNames LocalOptionBlocSize { const FParameterNames LocalOptionBlocSize {
{"-bs"}, {"-bs"},
"The size of the block of the blocked tree" "The size of the block of the blocked tree"
...@@ -105,9 +104,9 @@ int main(int argc, char* argv[]){ ...@@ -105,9 +104,9 @@ int main(int argc, char* argv[]){
LoaderClass loader(filename); LoaderClass loader(filename);
#endif #endif
int mpi_rank, nproc = 8, provided; int mpi_rank, nproc = 8, provided;
MPI_Init_thread(nullptr,nullptr, MPI_THREAD_SERIALIZED, &provided); FMpi mpiComm(argc,argv);
MPI_Comm_rank(MPI_COMM_WORLD,&mpi_rank); mpi_rank = mpiComm.global().processId();
MPI_Comm_size(MPI_COMM_WORLD,&nproc); nproc = mpiComm.global().processCount();
FAssertLF(loader.isOpen()); FAssertLF(loader.isOpen());
// Usual octree // Usual octree
...@@ -147,9 +146,9 @@ int main(int argc, char* argv[]){ ...@@ -147,9 +146,9 @@ int main(int argc, char* argv[]){
// Run the algorithm // Run the algorithm
FTic timerExecute;
GroupKernelClass groupkernel; GroupKernelClass groupkernel;
GroupAlgorithm groupalgo(&groupedTree,&groupkernel, distributedMortonIndex); GroupAlgorithm groupalgo(&groupedTree,&groupkernel, distributedMortonIndex);
FTic timerExecute;
groupalgo.execute(); groupalgo.execute();
double elapsedTime = timerExecute.tacAndElapsed(); double elapsedTime = timerExecute.tacAndElapsed();
timeAverage(mpi_rank, nproc, elapsedTime); timeAverage(mpi_rank, nproc, elapsedTime);
...@@ -31,6 +31,8 @@ using namespace std; ...@@ -31,6 +31,8 @@ using namespace std;
#include "../../Src/GroupTree/Chebyshev/FChebCellPOD.hpp" #include "../../Src/GroupTree/Chebyshev/FChebCellPOD.hpp"
#include "../../Src/Kernels/Chebyshev/FChebSymKernel.hpp" #include "../../Src/Kernels/Chebyshev/FChebSymKernel.hpp"
#include "Kernels/Interpolation/FInterpMatrixKernel.hpp" #include "Kernels/Interpolation/FInterpMatrixKernel.hpp"
#include "../../Src/Kernels/Chebyshev/FChebCell.hpp" //For validation
#include "../../Src/Core/FFmmAlgorithm.hpp" //For validation
#include "../../Src/BalanceTree/FLeafBalance.hpp" #include "../../Src/BalanceTree/FLeafBalance.hpp"
...@@ -68,14 +70,14 @@ void sortParticle(FPoint<FReal> * allParticlesToSort, int treeHeight, int groupS ...@@ -68,14 +70,14 @@ void sortParticle(FPoint<FReal> * allParticlesToSort, int treeHeight, int groupS
{"-bs"}, {"-bs"},
FHelpDescribeAndExit(argc, argv, "Test the blocked tree by counting the particles.", const FParameterNames LocalOptionNoValidate { {"-no-validation"}, "To avoid comparing with direct computation"};
FHelpDescribeAndExit(argc, argv, "Loutre",
FParameterDefinitions::OctreeHeight, FParameterDefinitions::NbParticles, FParameterDefinitions::OctreeHeight, FParameterDefinitions::NbParticles,
FParameterDefinitions::OctreeSubHeight, FParameterDefinitions::InputFile, LocalOptionBlocSize); FParameterDefinitions::OctreeSubHeight, FParameterDefinitions::InputFile, LocalOptionBlocSize, LocalOptionNoValidate);
// Get params // Get params
const int NbLevels = FParameters::getValue(argc,argv,FParameterDefinitions::OctreeHeight.options, 5); const int NbLevels = FParameters::getValue(argc,argv,FParameterDefinitions::OctreeHeight.options, 5);
...@@ -92,10 +94,10 @@ int main(int argc, char* argv[]){ ...@@ -92,10 +94,10 @@ int main(int argc, char* argv[]){
const char* const filename = FParameters::getStr(argc,argv,FParameterDefinitions::InputFile.options, "../Data/test20k.fma"); const char* const filename = FParameters::getStr(argc,argv,FParameterDefinitions::InputFile.options, "../Data/test20k.fma");
#endif #endif
int mpi_rank, nproc = 8, provided; int mpi_rank, nproc, provided;
FPoint<FReal> * allParticlesToSort = new FPoint<FReal>[loader.getNumberOfParticles()]; FPoint<FReal> * allParticlesToSort = new FPoint<FReal>[loader.getNumberOfParticles()];
...@@ -112,23 +114,129 @@ int main(int argc, char* argv[]){ ...@@ -112,23 +114,129 @@ int main(int argc, char* argv[]){
FReal physicalValue = 0.1; FReal physicalValue = 0.1;
allParticles.push(allParticlesToSort[idxPart], physicalValue); allParticles.push(allParticlesToSort[idxPart], physicalValue);
delete allParticlesToSort;
allParticlesToSort = nullptr;
// Put the data into the tree // Put the data into the tree
//GroupOctreeClass groupedTree(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox(), groupSize, &allParticles, false); //GroupOctreeClass groupedTree(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox(), groupSize, &allParticles, false);
GroupOctreeClass groupedTree(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox(), groupSize, &allParticles, sizeForEachGroup, false); GroupOctreeClass groupedTree(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox(), groupSize, &allParticles, sizeForEachGroup, true);
FTic timerExecute; int operationsToProceed = FFmmP2M | FFmmM2M | FFmmM2L | FFmmL2L | FFmmL2P | FFmmP2P;
const MatrixKernelClass MatrixKernel; const MatrixKernelClass MatrixKernel;
GroupKernelClass groupkernel(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox(), &MatrixKernel); GroupKernelClass groupkernel(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox(), &MatrixKernel);
groupalgo.execute(); FTic timerExecute;
groupalgo.execute(operationsToProceed);
// Validate the result // Validate the result
if(FParameters::existParameter(argc, argv, LocalOptionNoValidate.options) == false){
typedef FP2PParticleContainer<FReal> ContainerClass;
typedef FSimpleLeaf<FReal, ContainerClass > LeafClass;
typedef FChebCell<FReal,ORDER> CellClass;
typedef FOctree<FReal, CellClass,ContainerClass,LeafClass> OctreeClass;
typedef FChebSymKernel<FReal,CellClass,ContainerClass,MatrixKernelClass,ORDER> KernelClass;
typedef FFmmAlgorithm<OctreeClass,CellClass,ContainerClass,KernelClass,LeafClass> FmmClass;
const FReal epsi = 1E-10;
OctreeClass treeCheck(NbLevels, 2,loader.getBoxWidth(),loader.getCenterOfBox());
for(FSize idxPart = 0 ; idxPart < loader.getNumberOfParticles() ; ++idxPart){
// put in tree
treeCheck.insert(allParticlesToSort[idxPart], 0.1);
KernelClass kernels(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox(), &MatrixKernel);
FmmClass algorithm(&treeCheck, &kernels);
algorithm.execute(operationsToProceed);
groupedTree.forEachCellWithLevel([&](GroupCellClass gcell, const int level){
if(groupalgo.isDataOwnedBerenger(gcell.getMortonIndex(), level))
const CellClass* cell = treeCheck.getCell(gcell.getMortonIndex(), level);
if(cell == nullptr){
std::cout << "[Empty] Error cell should exist " << gcell.getMortonIndex() << "\n";
else {
FMath::FAccurater<FReal> diffUp;
diffUp.add(cell->getMultipole(0), gcell.getMultipole(0), gcell.getVectorSize());
if(diffUp.getRelativeInfNorm() > epsi || diffUp.getRelativeL2Norm() > epsi){
std::cout << "[Up] Up is different at index " << gcell.getMortonIndex() << " level " << level << " is " << diffUp << "\n";
FMath::FAccurater<FReal> diffDown;
diffDown.add(cell->getLocal(0), gcell.getLocal(0), gcell.getVectorSize());
if(diffDown.getRelativeInfNorm() > epsi || diffDown.getRelativeL2Norm() > epsi){
std::cout << "[Down] Down is different at index " << gcell.getMortonIndex() << " level " << level << " is " << diffDown << "\n";
groupedTree.forEachCellLeaf<FP2PGroupParticleContainer<FReal> >([&](GroupCellClass gcell, FP2PGroupParticleContainer<FReal> * leafTarget){
if(groupalgo.isDataOwnedBerenger(gcell.getMortonIndex(), NbLevels-1))
const ContainerClass* targets = treeCheck.getLeafSrc(gcell.getMortonIndex());
if(targets == nullptr){
std::cout << "[Empty] Error leaf should exist " << gcell.getMortonIndex() << "\n";
else{
const FReal*const gposX = leafTarget->getPositions()[0];
const FReal*const gposY = leafTarget->getPositions()[1];
const FReal*const gposZ = leafTarget->getPositions()[2];
const FSize gnbPartsInLeafTarget = leafTarget->getNbParticles();
const FReal*const gforceX = leafTarget->getForcesX();
const FReal*const gforceY = leafTarget->getForcesY();
const FReal*const gforceZ = leafTarget->getForcesZ();
const FReal*const gpotential = leafTarget->getPotentials();
const FReal*const posX = targets->getPositions()[0];
const FReal*const posY = targets->getPositions()[1];
const FReal*const posZ = targets->getPositions()[2];
const FSize nbPartsInLeafTarget = targets->getNbParticles();
const FReal*const forceX = targets->getForcesX();
const FReal*const forceY = targets->getForcesY();
const FReal*const forceZ = targets->getForcesZ();
const FReal*const potential = targets->getPotentials();
if(gnbPartsInLeafTarget != nbPartsInLeafTarget){
std::cout << "[Empty] Not the same number of particles at " << gcell.getMortonIndex()
<< " gnbPartsInLeafTarget " << gnbPartsInLeafTarget << " nbPartsInLeafTarget " << nbPartsInLeafTarget << "\n";
}else{
FMath::FAccurater<FReal> potentialDiff;
FMath::FAccurater<FReal> fx, fy, fz;
for(FSize idxPart = 0 ; idxPart < nbPartsInLeafTarget ; ++idxPart){
if(gposX[idxPart] != posX[idxPart] || gposY[idxPart] != posY[idxPart] || gposZ[idxPart] != posZ[idxPart]){
std::cout << "[Empty] Not the same particlea at " << gcell.getMortonIndex() << " idx " << idxPart << " "
<< gposX[idxPart] << " " << posX[idxPart] << " " << gposY[idxPart] << " " << posY[idxPart]
<< " " << gposZ[idxPart] << " " << posZ[idxPart] << "\n";
else{
potentialDiff.add(potential[idxPart], gpotential[idxPart]);
fx.add(forceX[idxPart], gforceX[idxPart]);
fy.add(forceY[idxPart], gforceY[idxPart]);
fz.add(forceZ[idxPart], gforceZ[idxPart]);
if(potentialDiff.getRelativeInfNorm() > epsi || potentialDiff.getRelativeL2Norm() > epsi){
std::cout << "[Up] potentialDiff is different at index " << gcell.getMortonIndex() << " is " << potentialDiff << "\n";
if(fx.getRelativeInfNorm() > epsi || fx.getRelativeL2Norm() > epsi){
std::cout << "[Up] fx is different at index " << gcell.getMortonIndex() << " is " << fx << "\n";
if(fy.getRelativeInfNorm() > epsi || fy.getRelativeL2Norm() > epsi){
std::cout << "[Up] fy is different at index " << gcell.getMortonIndex() << " is " << fy << "\n";
if(fz.getRelativeInfNorm() > epsi || fz.getRelativeL2Norm() > epsi){
std::cout << "[Up] fz is different at index " << gcell.getMortonIndex() << " is " << fz << "\n";
//std::cout << "Comparing is over" << std::endl;
return 0; return 0;
void timeAverage(int mpi_rank, int nproc, double elapsedTime) void timeAverage(int mpi_rank, int nproc, double elapsedTime)
...@@ -49,7 +49,6 @@ ...@@ -49,7 +49,6 @@
void timeAverage(int mpi_rank, int nproc, double elapsedTime); void timeAverage(int mpi_rank, int nproc, double elapsedTime);
{"-bs"}, {"-bs"},
...@@ -188,9 +187,9 @@ int main(int argc, char* argv[]){ ...@@ -188,9 +187,9 @@ int main(int argc, char* argv[]){
&allParticles, true, leftLimite); &allParticles, true, leftLimite);
FTic timerExecute;
GroupAlgorithm groupalgo(mpiComm.global(), &groupedTree,&groupkernel); GroupAlgorithm groupalgo(mpiComm.global(), &groupedTree,&groupkernel);
FTic timerExecute;
mpiComm.global().barrier(); mpiComm.global().barrier();
...@@ -52,7 +52,6 @@ ...@@ -52,7 +52,6 @@
const FParameterNames LocalOptionBlocSize { {"-bs"}, "The size of the block of the blocked tree"}; const FParameterNames LocalOptionBlocSize { {"-bs"}, "The size of the block of the blocked tree"};
const FParameterNames LocalOptionNoValidate { {"-no-validation"}, "To avoid comparing with direct computation"}; const FParameterNames LocalOptionNoValidate { {"-no-validation"}, "To avoid comparing with direct computation"};
FHelpDescribeAndExit(argc, argv, "Test the blocked tree by counting the particles.", FHelpDescribeAndExit(argc, argv, "Test the blocked tree by counting the particles.",
...@@ -200,19 +199,18 @@ int main(int argc, char* argv[]){ ...@@ -200,19 +199,18 @@ int main(int argc, char* argv[]){
GroupOctreeClass groupedTree(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(), groupSize, GroupOctreeClass groupedTree(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(), groupSize,
&myParticlesInContainer, true, leftLimite); &myParticlesInContainer, true, leftLimite);
//groupedTree.printInfoBlocks(); //groupedTree.printInfoBlocks();
timer.tac(); timer.tac();
//std::cerr << "Done " << "(@Creating and Inserting Particles = " << timer.elapsed() << "s)." << std::endl; //std::cerr << "Done " << "(@Creating and Inserting Particles = " << timer.elapsed() << "s)." << std::endl;
//std::cout << "\nChebyshev FMM (ORDER="<< ORDER << ") ... " << std::endl; //std::cout << "\nChebyshev FMM (ORDER="<< ORDER << ") ... " << std::endl;
timer.tic();
// Create Matrix Kernel // Create Matrix Kernel
GroupKernelClass groupkernel(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(), &MatrixKernel); GroupKernelClass groupkernel(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(), &MatrixKernel);
timer.tic();
