Commit 28277587 authored by Florent Pruvost's avatar Florent Pruvost
append FFT libraries only if found, for non MKL case also
parent 43d5beaa
...@@ -349,13 +349,18 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -349,13 +349,18 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
# MKL, THREADS|OMP and/or SIMPLE|DOUBLE|LONG|QUAD # MKL, THREADS|OMP and/or SIMPLE|DOUBLE|LONG|QUAD
# Default is DOUBLE and without THREADS|OMP # Default is DOUBLE and without THREADS|OMP
find_package(FFTW) # not REQUIRED find_package(FFTW) # not REQUIRED
if (FFTW_LIBRARY_DIRS_DEP)
set(FFT_LIBRARIES "-L${FFTW_LIBRARY_DIRS_DEP};" CACHE STRING "Set your MKL flags") set(FFT_LIBRARIES "-L${FFTW_LIBRARY_DIRS_DEP};" CACHE STRING "Set your MKL flags")
foreach (fft_lib ${FFTW_LIBRARIES_DEP}) endif()
set(FFT_LIBRARIES "${FFT_LIBRARIES} ${fft_lib};") if (FFTW_LIBRARIES_DEP)
endforeach() foreach (fft_lib ${FFTW_LIBRARIES_DEP})
endforeach()
endif()
set(FFT_INCLUDES "${FFTW_INCLUDE_DIRS_DEP}" ) set(FFT_INCLUDES "${FFTW_INCLUDE_DIRS_DEP}" )
set(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES}; ${FFT_LIBRARIES}") if (FFT_LIBRARIES)
endif()
endif(SCALFMM_USE_MKL_AS_FFTW) endif(SCALFMM_USE_MKL_AS_FFTW)
