Commit 26fd25a5 authored by berenger-bramas's avatar berenger-bramas
Remove the usage of the cblas functions in the kernel.
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/scalfmm/scalfmm/trunk@397 2616d619-271b-44dc-8df4-d4a8f33a7222
parent d2cf3103
...@@ -186,9 +186,9 @@ public: ...@@ -186,9 +186,9 @@ public:
//FReal alpha_and_beta[2] = {1.0, 0.0}; //FReal alpha_and_beta[2] = {1.0, 0.0};
//CblasTrans //CblasTrans
FBlas::gemtva( FBlas::c_gemtva(
static_cast<unsigned int>(FF_MATRIX_ROW_DIM),
static_cast<unsigned int>(FF_MATRIX_COLUMN_DIM), static_cast<unsigned int>(FF_MATRIX_COLUMN_DIM),
FReal(1.0), FReal(1.0),
(FReal*)M2L_Outer_transfer, (FReal*)M2L_Outer_transfer,
(FReal*)temporaryMultiSource, (FReal*)temporaryMultiSource,
...@@ -186,12 +186,13 @@ public: ...@@ -186,12 +186,13 @@ public:
FBlas::gemtv( static_cast<unsigned int>(FF_MATRIX_COLUMN_DIM), FBlas::c_gemtva(
static_cast<unsigned int>(FF_MATRIX_ROW_DIM), static_cast<unsigned int>(FF_MATRIX_COLUMN_DIM),
FReal(1.0), static_cast<unsigned int>(FF_MATRIX_ROW_DIM),
(FReal*)M2L_Outer_transfer, FReal(1.0),
(FReal*)temporaryMultiSource, (FReal*)M2L_Outer_transfer,
(FReal*)local_exp); (FReal*)temporaryMultiSource,
(FReal*)local_exp);
