Commit 205e4ce2 authored by COULAUD Olivier's avatar COULAUD Olivier
Add comments
parent f52f6632
...@@ -38,6 +38,7 @@ SET(ScalFMM_VERSION "${ScalFMM_MAJOR_VERSION}.${ScalFMM_MINOR_VERSION}.${ScalFM ...@@ -38,6 +38,7 @@ SET(ScalFMM_VERSION "${ScalFMM_MAJOR_VERSION}.${ScalFMM_MINOR_VERSION}.${ScalFM
# Active language # Active language
ENABLE_LANGUAGE(CXX ) ENABLE_LANGUAGE(CXX )
if( ScalFMM_USE_MPI ) if( ScalFMM_USE_MPI )
TRY_COMPILE(COMPILE_INTEL ${CMAKE_CURRENT_BINARY_DIR} ${CMAKE_MODULE_PATH}/compileTestIntel.cpp COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS}") TRY_COMPILE(COMPILE_INTEL ${CMAKE_CURRENT_BINARY_DIR} ${CMAKE_MODULE_PATH}/compileTestIntel.cpp COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS}")
if (COMPILE_INTEL) if (COMPILE_INTEL)
