Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 205e4ce2 authored by COULAUD Olivier's avatar COULAUD Olivier
Add comments
parent f52f6632
...@@ -14,9 +14,9 @@ SET(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/CMakeModules) ...@@ -14,9 +14,9 @@ SET(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/CMakeModules)
# MPI option has to be set before project, cannot be changed in the cache! # MPI option has to be set before project, cannot be changed in the cache!
if( ScalFMM_USE_MPI ) if( ScalFMM_USE_MPI )
include(CMakeForceCompiler) include(CMakeForceCompiler)
CMAKE_FORCE_C_COMPILER(mpicc "MPI C Compiler") CMAKE_FORCE_C_COMPILER(mpicc "MPI C Compiler")
CMAKE_FORCE_CXX_COMPILER(mpicxx "MPI C++ Compiler") CMAKE_FORCE_CXX_COMPILER(mpicxx "MPI C++ Compiler")
set(ScalFMM_USE_MPI ON CACHE BOOL "ScalFmm use MPI") set(ScalFMM_USE_MPI ON CACHE BOOL "ScalFmm use MPI")
else() else()
MESSAGE(STATUS "Remove CMake cache and run cmake .. -DScalFMM_USE_MPI=ON to enable MPI" ) MESSAGE(STATUS "Remove CMake cache and run cmake .. -DScalFMM_USE_MPI=ON to enable MPI" )
endif(ScalFMM_USE_MPI) endif(ScalFMM_USE_MPI)
...@@ -38,6 +38,7 @@ SET(ScalFMM_VERSION "${ScalFMM_MAJOR_VERSION}.${ScalFMM_MINOR_VERSION}.${ScalFM ...@@ -38,6 +38,7 @@ SET(ScalFMM_VERSION "${ScalFMM_MAJOR_VERSION}.${ScalFMM_MINOR_VERSION}.${ScalFM
# Active language # Active language
ENABLE_LANGUAGE(CXX ) ENABLE_LANGUAGE(CXX )
TRY_COMPILE(COMPILE_INTEL ${CMAKE_CURRENT_BINARY_DIR} ${CMAKE_MODULE_PATH}/compileTestIntel.cpp COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS}") TRY_COMPILE(COMPILE_INTEL ${CMAKE_CURRENT_BINARY_DIR} ${CMAKE_MODULE_PATH}/compileTestIntel.cpp COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS}")
if (COMPILE_INTEL) if (COMPILE_INTEL)
