Commit 1e473205 authored by berenger-bramas's avatar berenger-bramas
Tests for the block blas kernel.
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/scalfmm/scalfmm/trunk@423 2616d619-271b-44dc-8df4-d4a8f33a7222
parent 3b6650ac
...@@ -75,7 +75,7 @@ public: ...@@ -75,7 +75,7 @@ public:
downardPass(); downardPass();
directPass(); directPass();
private: private:
...@@ -202,7 +202,7 @@ public: ...@@ -202,7 +202,7 @@ public:
void P2P(const FTreeCoordinate& inLeafPosition, void P2P(const FTreeCoordinate& inLeafPosition,
ContainerClass* const FRestrict targets, const ContainerClass* const FRestrict sources, ContainerClass* const FRestrict targets, const ContainerClass* const FRestrict sources,
ContainerClass* const directNeighborsParticles[27], const int size){ ContainerClass* const directNeighborsParticles[27], const int /*size*/){
if( periodicLevels == 0 && targets == sources ){ if( periodicLevels == 0 && targets == sources ){
P2PNoTsm(targets, directNeighborsParticles); P2PNoTsm(targets, directNeighborsParticles);
...@@ -72,7 +72,6 @@ protected: ...@@ -72,7 +72,6 @@ protected:
else{ else{
(*fillTransfer) = blasHarmonic.result()[blasHarmonic.getPreExpRedirJ(M+N)+k]; (*fillTransfer) = blasHarmonic.result()[blasHarmonic.getPreExpRedirJ(M+N)+k];
...@@ -122,7 +121,7 @@ public: ...@@ -122,7 +121,7 @@ public:
/** M2L with a cell and all the existing neighbors */ /** M2L with a cell and all the existing neighbors */
void M2L(CellClass* const FRestrict pole, const CellClass* distantNeighbors[343], void M2L(CellClass* const FRestrict pole, const CellClass* distantNeighbors[343],
const int /*size*/, const int inLevel) { const int /*size*/, const int inLevel) {
// For all neighbors compute M2L // For all neighbors compute M2L
for(int idxNeigh = 0 ; idxNeigh < 343 ; ++idxNeigh){ for(int idxNeigh = 0 ; idxNeigh < 343 ; ++idxNeigh){
if( distantNeighbors[idxNeigh] ){ if( distantNeighbors[idxNeigh] ){
...@@ -191,13 +190,7 @@ public: ...@@ -191,13 +190,7 @@ public:
(FReal*)M2L_Outer_transfer, (FReal*)M2L_Outer_transfer,
(FReal*)temporaryMultiSource, (FReal*)temporaryMultiSource,
(FReal*)local_exp); (FReal*)local_exp);
// TODO delete
static int count = 0;
if( FMath::IsNan(local_exp[CellClass::GetLocalSize()-1].getReal()) && count != -1){
std::cout << "count is " << count << std::endl;
count = -1;
if(count != -1) count++;
