Commit 1ca97c8c authored by PIACIBELLO Cyrille's avatar PIACIBELLO Cyrille
Changes for avoiding zero traited as null ptr
parent 42c991d5
......@@ -45,6 +45,7 @@ public:
* so this struct store a particle + its index
struct IndexedParticle{
public:
MortonIndex index;
ParticleClass particle;
......@@ -181,7 +182,7 @@ private:
const bool needToRecvBeforeSend = (rank != 0 && (((*workingSize) && otherFirstIndex == workingArray[0].index ) || !(*workingSize)));
MPI_Request requestSendLeaf;
IndexedParticle* sendBuffer = 0;
IndexedParticle* sendBuffer = nullptr;
if(rank != nbProcs - 1 && needToRecvBeforeSend == false){
FSize idxPart = (*workingSize) - 1 ;
while(idxPart >= 0 && workingArray[idxPart].index == otherFirstIndex){
......@@ -197,7 +198,7 @@ private:
rank + 1, FMpi::TagSplittedLeaf, communicator.getComm(), &requestSendLeaf);
else{
MPI_Isend( 0, 0, MPI_BYTE, rank + 1, FMpi::TagSplittedLeaf, communicator.getComm(), &requestSendLeaf);
MPI_Isend( nullptr, 0, MPI_BYTE, rank + 1, FMpi::TagSplittedLeaf, communicator.getComm(), &requestSendLeaf);
......@@ -223,7 +224,7 @@ private:
rank - 1, FMpi::TagSplittedLeaf, communicator.getComm(), MPI_STATUS_IGNORE);
else{
MPI_Recv( 0, 0, MPI_BYTE, rank - 1, FMpi::TagSplittedLeaf, communicator.getComm(), MPI_STATUS_IGNORE);
MPI_Recv( nullptr, 0, MPI_BYTE, rank - 1, FMpi::TagSplittedLeaf, communicator.getComm(), MPI_STATUS_IGNORE);
......@@ -231,21 +232,21 @@ private:
MPI_Send( workingArray, int((*workingSize) * sizeof(IndexedParticle)), MPI_BYTE,
rank + 1, FMpi::TagSplittedLeaf, communicator.getComm());
delete[] workingArray;
workingArray = 0;
workingArray = nullptr;
(*workingSize) = 0;
else if(rank != nbProcs - 1){
MPI_Wait( &requestSendLeaf, MPI_STATUS_IGNORE);
delete[] sendBuffer;
sendBuffer = 0;
{//Filling the Array with leaves and parts //// COULD BE MOVED IN AN OTHER FUCTION
(*leavesSize) = 0; //init ptr
(*leavesArray) = 0; //init ptr
(*leavesIndices) = 0; //init ptr
(*leavesArray) = nullptr; //init ptr
(*leavesIndices) = nullptr; //init ptr
if((*workingSize)){
......@@ -275,7 +276,7 @@ private:
delete [] workingArray;
workingArray = 0;
......@@ -337,8 +338,8 @@ private:
for(int idxProc = 0 ; idxProc < nbProcs ; ++idxProc){
if(idxProc != myRank){
const FSize correctLeftLeafNumber = balancer->getLeft(totalNumberOfLeaves,NULL,0,0,nbProcs,idxProc);
const FSize correctRightLeafNumber = balancer->getRight(totalNumberOfLeaves,NULL,0,0,nbProcs,idxProc);
const FSize correctLeftLeafNumber = balancer->getLeft(totalNumberOfLeaves,nullptr,0,nullptr,nbProcs,idxProc);
const FSize correctRightLeafNumber = balancer->getRight(totalNumberOfLeaves,nullptr,0,nullptr,nbProcs,idxProc);
//5 cases : Refer to ParalleleDetails.pdf to know more
......@@ -532,14 +533,14 @@ public:
const FPoint& boxCenter, const FReal boxWidth, const int treeHeight,
ContainerClass* particleSaver, FAbstractBalanceAlgorithm* balancer,const SortingType type = QuickSort){
IndexedParticle* particlesArray = 0;
IndexedParticle* particlesArray = nullptr;
FSize particlesSize = 0;
SortParticlesFromArray(communicator, array, size, type, boxCenter, boxWidth, treeHeight,
&particlesArray, &particlesSize);
ParticleClass* leavesArray = 0;
ParticleClass* leavesArray = nullptr;
FSize leavesSize = 0;
FSize * leavesIndices = 0;
FSize * leavesIndices = nullptr;
MergeLeaves(communicator, particlesArray, &particlesSize, &leavesIndices, &leavesArray, &leavesSize);
......@@ -547,7 +548,7 @@ public:
/** To produce stats after the Equalize phase
int* nbPartsPerProc = {0};
int* nbPartsPerProc;
int myParts = particleSaver->getSize();
int nbProc = communicator.processCount();
......@@ -45,7 +45,7 @@ public:
// receiving buffer
IndexType bufferSize = 0;
SortType* buffer = 0;
SortType* buffer = nullptr;
// Create the first com
FMpi::FComm currentComm(originalComm.getComm());
