Commit 15607f11 authored by BRAMAS Berenger's avatar BRAMAS Berenger
add old distribution into block unif compare
parent 64cdf22a
...@@ -59,7 +59,7 @@ ...@@ -59,7 +59,7 @@
#include "Utils/FTemplate.hpp" #include "Utils/FTemplate.hpp"
//#define RANDOM_PARTICLES #define RANDOM_PARTICLES
const FParameterNames LocalOrder { {"-order"}, "Order of the kernel"}; const FParameterNames LocalOrder { {"-order"}, "Order of the kernel"};
const FParameterNames LocalOptionOmpTask { {"-omp-task"}, "To use FFmmAlgorithmTask"}; const FParameterNames LocalOptionOmpTask { {"-omp-task"}, "To use FFmmAlgorithmTask"};
...@@ -69,6 +69,281 @@ const FParameterNames LocalOptionOmpBalance { {"-omp-balance"}, "To use FFmmAlgo ...@@ -69,6 +69,281 @@ const FParameterNames LocalOptionOmpBalance { {"-omp-balance"}, "To use FFmmAlgo
const FParameterNames LocalOptionClassic { {"-omp", "omp-classic"}, "In order to use classic parallelism"}; const FParameterNames LocalOptionClassic { {"-omp", "omp-classic"}, "In order to use classic parallelism"};
const FParameterNames LocalOptionBlocSize { {"-bs"}, "The size of the block of the blocked tree"}; const FParameterNames LocalOptionBlocSize { {"-bs"}, "The size of the block of the blocked tree"};
const FParameterNames LocalOptionNoValidate { {"-no-validation"}, "To avoid comparing with direct computation"}; const FParameterNames LocalOptionNoValidate { {"-no-validation"}, "To avoid comparing with direct computation"};
const FParameterNames LocalOptionProlate { {"-prolate"}, "To generate prolate distribution"};
#include <cstdlib>
#include <time.h>
* @author Berenger Bramas (berenger.bramas@inria.fr)
* @class FSphericalRandomLoader
* Please read the license
template <class FReal>
class FSphericalRandomLoader : public FAbstractLoader<FReal> {
protected:
const int nbParticles; //< the number of particles
const FReal boxWidth; //< the box width
const FPoint<FReal> centerOfBox; //< The center of box
const bool nu;
const bool snu;
const bool su;
const bool elu;
const bool ssnu;
const bool elsu;
FReal rotationMatrix[3][3];
void initRotationMatrix(){
const FReal alpha = FMath::FPi<FReal>()/8;
const FReal omega = FMath::FPi<FReal>()/4;
FReal yrotation[3][3];
yrotation[0][0] = FMath::Cos(alpha); yrotation[0][1] = 0.0; yrotation[0][2] = FMath::Sin(alpha);
yrotation[1][0] = 0.0; yrotation[1][1] = 1.0; yrotation[1][2] = 0.0;
yrotation[2][0] = -FMath::Sin(alpha); yrotation[2][1] = 0.0; yrotation[2][2] = FMath::Cos(alpha);
FReal zrotation[3][3];
zrotation[0][0] = FMath::Cos(omega); zrotation[0][1] = -FMath::Sin(omega); zrotation[0][2] = 0.0;
zrotation[1][0] = FMath::Sin(omega); zrotation[1][1] = FMath::Cos(omega); zrotation[1][2] = 0.0;
zrotation[2][0] = 0.0; zrotation[2][1] = 0.0; zrotation[2][2] = 1.0;
for(int i = 0 ; i < 3 ; ++i){
for(int j = 0 ; j < 3 ; ++j){
FReal sum = 0.0;
for(int k = 0 ; k < 3 ; ++k){
sum += zrotation[i][k] * yrotation[k][j];
rotationMatrix[i][j] = sum;
public:
* The constructor need the simulation data
FSphericalRandomLoader(const int inNbParticles, const bool inNu = false,
const bool inSnu = false,
const bool inSu = false,
const bool inElu = false,
const bool inSsnu = false,
const bool inElsu = false)
: nbParticles(inNbParticles), boxWidth(1.0), centerOfBox(0,0,0), nu(inNu),
snu(inSnu), su(inSu), elu(inElu), ssnu(inSsnu), elsu(inElsu) {
srand48(static_cast<unsigned int>(0));
if( !nu && !snu && !su && !elu && !ssnu && !elsu ){
std::cout << "UNIFORM" << std::endl;
else if( snu ){
std::cout << "slightly NON UNIFORM" << std::endl;
else if( su ){
std::cout << "SPHERICAL UNIFORM" << std::endl;
else if( elu ){
std::cout << "ELLIPSE UNIFORM" << std::endl;
else if( elsu ){
std::cout << "ELLIPSE NON UNIFORM" << std::endl;
initRotationMatrix();
else if( ssnu ){
std::cout << "spherical Slightly non UNIFORM" << std::endl;
else{
std::cout << "NON UNIFORM" << std::endl;
* Default destructor
virtual ~FSphericalRandomLoader(){
* @return true
bool isOpen() const{
return true;
* To get the number of particles from this loader
* @param the number of particles the loader can fill
FSize getNumberOfParticles() const{
return FSize(this->nbParticles);
* The center of the box
* @return box center
FPoint<FReal> getCenterOfBox() const{
return this->centerOfBox;
* The box width
* @return box width
FReal getBoxWidth() const{
return this->boxWidth;
* Fill a particle
* @warning to work with the loader, particles has to expose a setPosition method
* @param the particle to fill
void fillParticle(FPoint<FReal>* partPtr){
FPoint<FReal>& inParticle = *partPtr;
inParticle.setPosition(
(getRandom() * boxWidth) + centerOfBox.getX() - boxWidth/2,
(getRandom() * boxWidth) + centerOfBox.getY() - boxWidth/2,
(getRandom() * boxWidth) + centerOfBox.getZ() - boxWidth/2);
else if( snu ){
const FReal XCenter = centerOfBox.getX();
const FReal YCenter = centerOfBox.getY();
const FReal ZCenter = centerOfBox.getZ();
const FReal rayon = FReal(0.4);
const FReal thresh = FReal(0.15);
const FReal threshDiv2 = thresh/2;
// Generate particles
const FReal theta = getRandom() * FMath::FPi<FReal>();
const FReal omega = getRandom() * FMath::FPi<FReal>() * FReal(2);
const FReal px = rayon * FMath::Cos(omega) * FMath::Sin(theta) + XCenter + thresh * getRandom() - threshDiv2;
const FReal py = rayon * FMath::Sin(omega) * FMath::Sin(theta) + YCenter + thresh * getRandom() - threshDiv2;
const FReal pz = rayon * FMath::Cos(theta) + ZCenter + thresh * getRandom() - threshDiv2;
inParticle.setPosition(px,py,pz);
else if( su ){
//http://www.cs.cmu.edu/~mws/rpos.html
const FReal r = 0.4;
const FReal pz = getRandom()*2.0*r - r;
const FReal theta = FMath::ASin(pz/r);
const FReal px = r * cos(theta) * cos(omega);
const FReal py = r * cos(theta) * sin(omega);
else if( elu ){
const FReal a = 0.4;
const FReal b = 0.15;
const FReal maxPerimeter = 2.0 * FMath::FPi<FReal>() * a;
FReal px = 0;
// rayon du cercle pour ce x
FReal subr = 0;
do {
px = (getRandom() * a * 2) - a;
subr = FMath::Sqrt( (1.0 - ((px*px)/(a*a))) * (b*b) );
} while( (getRandom()*maxPerimeter) > subr );
// on genere un angle
// on recupere py et pz sur le cercle
const FReal py = FMath::Cos(omega) * subr;
const FReal pz = FMath::Sin(omega) * subr;
else if( elsu ){
const FReal a = 0.5;
const FReal b = 0.1;
const FReal MaxDensity = 10.0;
const FReal maxPerimeter = 2.0 * FMath::FPi<FReal>() * a ;
FReal px = 0;
FReal subr = 0;
FReal coef = 1.0;
do {
//px = ( ((getRandom()*8.0+getRandom())/9.0) * a * 2) - a;
px = (getRandom() * a * 2.0) - a;
coef = FMath::Abs(px) * MaxDensity/a + 1.0;
} while( (getRandom()*maxPerimeter) > subr * coef );
// inParticle.setPosition(px,py,pz);
inParticle.setPosition(px * rotationMatrix[0][0] + py * rotationMatrix[0][1]+ pz * rotationMatrix[0][2],
px * rotationMatrix[1][0] + py * rotationMatrix[1][1]+ pz * rotationMatrix[1][2],
px * rotationMatrix[2][0] + py * rotationMatrix[2][1]+ pz * rotationMatrix[2][2]);
else if( ssnu ){
/*static const int NbAcc = 2;
FReal acc = 0;
for(int idx = 0 ; idx < NbAcc ; ++idx){
acc += getRandom()/FReal(NbAcc);
FReal acc = ((getRandom()*8)+getRandom())/9;
const FReal theta = acc * FMath::FPi<FReal>();
const FReal px = rayon * FMath::Cos(omega) * FMath::Sin(theta) + XCenter ;
const FReal py = rayon * FMath::Sin(omega) * FMath::Sin(theta) + YCenter ;
const FReal pz = rayon * FMath::Cos(theta) + ZCenter ;
else{
/** Get a random number between 0 & 1 */
FReal getRandom() const{
return FReal(drand48());
struct RunContainer{ struct RunContainer{
template <const int ORDER> template <const int ORDER>
...@@ -95,7 +370,9 @@ struct RunContainer{ ...@@ -95,7 +370,9 @@ struct RunContainer{
// open particle file // open particle file
#ifdef RANDOM_PARTICLES #ifdef RANDOM_PARTICLES
FRandomLoader<FReal> loader(FParameters::getValue(argc,argv,FParameterDefinitions::NbParticles.options, 2000), 1.0, FPoint<FReal>(0,0,0), 0); const bool prolate = FParameters::existParameter(argc,argv,LocalOptionProlate.options);
FSphericalRandomLoader<FReal> loader(FParameters::getValue(argc,argv,FParameterDefinitions::NbParticles.options, 2000),
!prolate, false, false, prolate, false, false);
#else #else
const char* const filename = FParameters::getStr(argc,argv,FParameterDefinitions::InputFile.options, "../Data/test20k.fma"); const char* const filename = FParameters::getStr(argc,argv,FParameterDefinitions::InputFile.options, "../Data/test20k.fma");
FFmaGenericLoader<FReal> loader(filename); FFmaGenericLoader<FReal> loader(filename);
...@@ -285,7 +562,9 @@ struct RunContainer{ ...@@ -285,7 +562,9 @@ struct RunContainer{
// Load the particles // Load the particles
#else #else
...@@ -398,7 +677,7 @@ int main(int argc, char* argv[]){ ...@@ -398,7 +677,7 @@ int main(int argc, char* argv[]){
FHelpDescribeAndExit(argc, argv, "Test the blocked tree by counting the particles.", FHelpDescribeAndExit(argc, argv, "Test the blocked tree by counting the particles.",
FParameterDefinitions::OctreeHeight, FParameterDefinitions::OctreeSubHeight, FParameterDefinitions::OctreeHeight, FParameterDefinitions::OctreeSubHeight,
FParameterDefinitions::NbParticles, FParameterDefinitions::NbParticles, LocalOptionProlate,
#else #else
FParameterDefinitions::InputFile, FParameterDefinitions::InputFile,
#endif #endif
...@@ -412,3 +691,8 @@ int main(int argc, char* argv[]){ ...@@ -412,3 +691,8 @@ int main(int argc, char* argv[]){
return 0; return 0;
