Commit 0d25c845 authored by COULAUD Olivier's avatar COULAUD Olivier
Merge branch 'develop' of gitlab.inria.fr:solverstack/ScalFMM into develop
parents 1fd27cc1 fc133b46
...@@ -70,16 +70,19 @@ using FmmClassProcPER = FFmmAlgorithmThreadProcPeriodic<FReal,OctreeClass,CellC ...@@ -70,16 +70,19 @@ using FmmClassProcPER = FFmmAlgorithmThreadProcPeriodic<FReal,OctreeClass,CellC
int main(int argc, char* argv[]) int main(int argc, char* argv[])
///////// PARAMETERS HANDLING ////////////////////////////////////// ///////// PARAMETERS HANDLING //////////////////////////////////////
// const FParameterNames localIncreaseBox = { {"ratio","-L"}, "Increase teh Box size by a factor L:= ratio"};
FHelpDescribeAndExit(argc, argv, FHelpDescribeAndExit(argc, argv,
"Driver for Interpolation Laplace kernel using MPI. " "Driver for Chebyshev Interpolation kernel using MPI (1/r kernel).\n "
"Usully run using : mpirun -np nb_proc_needed ./ChebyshevInterpolationAlgorithm [params].", "Usully run using : mpirun -np nb_proc_needed ./ChebyshevInterpolationAlgorithm [params].",
FParameterDefinitions::OctreeHeight, FParameterDefinitions::OctreeHeight,
FParameterDefinitions::OctreeSubHeight, FParameterDefinitions::OctreeSubHeight,
FParameterDefinitions::InputFile, FParameterDefinitions::InputFile,
FParameterDefinitions::OutputFile, FParameterDefinitions::OutputFile,
FParameterDefinitions::NbThreads, FParameterDefinitions::NbThreads,
FParameterDefinitions::PeriodicityNbLevels); FParameterDefinitions::PeriodicityNbLevels,
localIncreaseBox
const std::string defaultFile("../Data/test20k.fma"); const std::string defaultFile("../Data/test20k.fma");
const std::string filename = FParameters::getStr(argc,argv, FParameterDefinitions::InputFile.options, defaultFile.c_str()); const std::string filename = FParameters::getStr(argc,argv, FParameterDefinitions::InputFile.options, defaultFile.c_str());
...@@ -121,16 +124,25 @@ int main(int argc, char* argv[]) ...@@ -121,16 +124,25 @@ int main(int argc, char* argv[])
if(!loader.isOpen()) { if(!loader.isOpen()) {
throw std::runtime_error("Particle file couldn't be opened!") ; throw std::runtime_error("Particle file couldn't be opened!") ;
auto boxWidth = loader.getBoxWidth() ;
if(FParameters::existParameter(argc, argv, localIncreaseBox.options)){
FReal ratio= FParameters::getValue(argc, argv, localIncreaseBox.options, 1.0);
boxWidth *= ratio;
// Initialize empty oct-tree // Initialize empty oct-tree
OctreeClass tree(TreeHeight, SubTreeHeight, loader.getBoxWidth(), loader.getCenterOfBox()); OctreeClass tree(TreeHeight, SubTreeHeight, boxWidth, loader.getCenterOfBox());
FSize localParticlesNumber = 0 ; FSize localParticlesNumber = 0 ;
if(app.global().processId() == 0){ if(app.global().processId() == 0){
std::cout << "Loading & Inserting " << loader.getNumberOfParticles() std::cout << "Loading & Inserting " << loader.getNumberOfParticles()
<< " particles ..." << std::endl; << " particles ..." << std::endl
<<" Box: "<< std::endl
<< " width " << boxWidth << std::endl
<< " Centre " << loader.getCenterOfBox()<< std::endl;
std::cout << "\tHeight : " << TreeHeight << " \t sub-height : " << SubTreeHeight << std::endl; std::cout << "\tHeight : " << TreeHeight << " \t sub-height : " << SubTreeHeight << std::endl;
time.tic(); time.tic();
...@@ -221,7 +233,7 @@ int main(int argc, char* argv[]) ...@@ -221,7 +233,7 @@ int main(int argc, char* argv[])
// non periodic FMM algorithm // non periodic FMM algorithm
std::unique_ptr<KernelClass> kernelsNoPer(new KernelClass(TreeHeight, loader.getBoxWidth(), std::unique_ptr<KernelClass> kernelsNoPer(new KernelClass(TreeHeight, boxWidth,
loader.getCenterOfBox(),&MatrixKernel)); loader.getCenterOfBox(),&MatrixKernel));
FmmClassProc algoNoPer(app.global(),&tree, kernelsNoPer.get()); FmmClassProc algoNoPer(app.global(),&tree, kernelsNoPer.get());
...@@ -240,13 +252,12 @@ int main(int argc, char* argv[]) ...@@ -240,13 +252,12 @@ int main(int argc, char* argv[])
//timer = &algoPer ; //timer = &algoPer ;
// FMM exectution FFmmFarField // FMM exectution FFmmFarField FFmmNearField
algorithm->execute(); algorithm->execute(FFmmNearField);
time.tac(); time.tac();
double timeUsed = time.elapsed(); timeUsed = time.elapsed();
double minTime,maxTime;
std::cout << "Done " << "(@Algorithm = " << time.elapsed() << " s)." << std::endl; std::cout << "Done " << "(@Algorithm = " << time.elapsed() << " s)." << std::endl;
MPI_Reduce(&timeUsed,&minTime,1,MPI_DOUBLE,MPI_MIN,0,app.global().getComm()); MPI_Reduce(&timeUsed,&minTime,1,MPI_DOUBLE,MPI_MIN,0,app.global().getComm());
MPI_Reduce(&timeUsed,&maxTime,1,MPI_DOUBLE,MPI_MAX,0,app.global().getComm()); MPI_Reduce(&timeUsed,&maxTime,1,MPI_DOUBLE,MPI_MAX,0,app.global().getComm());
...@@ -270,7 +281,9 @@ FReal energy =0.0 ; ...@@ -270,7 +281,9 @@ FReal energy =0.0 ;
std::cout <<std::endl<<" &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& "<<std::endl; std::cout <<std::endl<<" &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& "<<std::endl;
std::cout << std::scientific; std::cout << std::scientific;
std::cout.precision(10) ; std::cout.precision(15) ;
FReal TotalPhysicalValue=0.0 ;
tree.forEachLeaf([&](LeafClass* leaf){ tree.forEachLeaf([&](LeafClass* leaf){
const FReal*const posX = leaf->getTargets()->getPositions()[0]; const FReal*const posX = leaf->getTargets()->getPositions()[0];
...@@ -294,11 +307,12 @@ tree.forEachLeaf([&](LeafClass* leaf){ ...@@ -294,11 +307,12 @@ tree.forEachLeaf([&](LeafClass* leaf){
<< " Forces: " << forcesX[idxPart] << " " << forcesY[idxPart] << " "<< forcesZ[idxPart] <<std::endl; << " Forces: " << forcesX[idxPart] << " " << forcesY[idxPart] << " "<< forcesZ[idxPart] <<std::endl;
energy += potentials[idxPart]*physicalValues[idxPart] ; energy += potentials[idxPart]*physicalValues[idxPart] ;
TotalPhysicalValue += physicalValues[idxPart] ;
FReal gloEnergy = app.global().reduceSum(energy); FReal gloEnergy = app.global().reduceSum(energy);
if(0 == app.global().processId()){ if(0 == app.global().processId()){
std::cout <<std::endl << "Proc "<< app.global().processId() << " Energy: "<< gloEnergy <<std::endl; std::cout <<std::endl<<"aboveRoot: " << aboveTree << " Energy: "<< energy<<" TotalPhysicalValue: " << TotalPhysicalValue<< std::endl; std::cout <<std::endl << "Proc "<< app.global().processId() << " Energy: "<< gloEnergy <<std::endl;
std::cout <<std::endl <<" &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& "<<std::endl<<std::endl; std::cout <<std::endl <<" &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&& "<<std::endl<<std::endl;
