GitLab
Support
Community forum
Keyboard shortcuts
S
ScalFMM
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
solverstack
ScalFMM
0ca11347
0ca11347
COULAUD Olivier
Merge branch 'master' of
git+ssh://scm.gforge.inria.fr//gitroot/scalfmm/scalfmm
parents
de9be7c4
15db427b
35
Expand all
35 changed files
175 additions
874 deletions
+175
-874
CMakeLists.txt
CMakeLists.txt
+4
-12
Src/AdaptiveTree/FAdaptChebSymKernel.hpp
+1
-1
Src/AdaptiveTree/FAdaptSeqAlgorithm.hpp
+7
-15
Src/AdaptiveTree/FAdaptUnifKernel.hpp
+1
-1
Src/Components/FTestKernels.hpp
+1
-1
Src/Core/FFmmAlgorithm.hpp
+1
-9
Src/Core/FFmmAlgorithmPeriodic.hpp
+1
-9
Src/Core/FFmmAlgorithmSectionTask.hpp
+1
-9
Src/Core/FFmmAlgorithmTask.hpp
+1
-7
Src/Core/FFmmAlgorithmThread.hpp
+1
-7
Src/Core/FFmmAlgorithmThreadProc.hpp
+138
-501
Src/Core/FFmmAlgorithmThreadProcPeriodic.hpp
+1
-1
Src/Core/FFmmAlgorithmThreadTsm.hpp
+1
-10
Src/Core/FFmmAlgorithmTsm.hpp
+1
-6
Src/Files/FMpiTreeBuilder.hpp
+1
-3
Src/Kernels/Chebyshev/FAbstractChebKernel.hpp
+1
-1
Src/Kernels/Chebyshev/FChebFlopsSymKernel.hpp
+1
-1
Src/Kernels/Chebyshev/FChebKernel.hpp
+1
-1
Src/Kernels/Chebyshev/FChebSymKernel.hpp
+1
-1
Src/Kernels/Chebyshev/FChebSymTensorialKernel.hpp
+1
-1
Src/Kernels/Chebyshev/FChebTensorialKernel.hpp
+1
-1
Src/Kernels/Spherical/FAbstractSphericalKernel.hpp
+1
-1
Src/Kernels/Uniform/FAbstractUnifKernel.hpp
+1
-1
Src/Kernels/Uniform/FUnifDenseKernel.hpp
+1
-1
Src/Kernels/Uniform/FUnifKernel.hpp
+1
-1
Src/Kernels/Uniform/FUnifSymKernel.hpp
+1
-1
Src/Kernels/Uniform/FUnifTensorialKernel.hpp
+1
-1
Src/ScalFmmConfig.h.cmake
+0
-8
Src/Utils/FBitonicSort.hpp
+1
-2
Src/Utils/FQuickSort.hpp
+1
-1
Src/Utils/FTrace.cpp
+0
-25
Src/Utils/FTrace.hpp
+0
-230
Tests/Kernels/testSphericalProcAlgorithm.cpp
+0
-1
Tests/noDist/testSphericalBlasBlockProc.cpp
+0
-2
Tests/noDist/testSphericalBlasProc.cpp
+0
-1
CMakeLists.txt
0ca11347
@@ -44,7 +44,6 @@ MESSAGE(STATUS " CXX ${CMAKE_CXX_COMPILER_ID}" )
# Options
# Options
OPTION
ScalFMM_USE_BLAS
"Set to ON to build ScaFMM with BLAS"
OFF
OPTION
ScalFMM_USE_BLAS
OFF
OPTION
ScalFMM_USE_FFT
"Set to ON to build ScaFMM with FFTW"
OFF
OPTION
ScalFMM_USE_FFT
OFF
OPTION
ScalFMM_USE_TRACE
"Set to ON to print trace or use itac trace"
OFF
OPTION
ScalFMM_BUILD_TESTS
"Set to ON to build functionalities Tests"
OFF
OPTION
ScalFMM_BUILD_TESTS
OFF
OPTION
ScalFMM_BUILD_UTESTS
"Set to ON to build UTests"
OFF
OPTION
OFF
OPTION
ScalFMM_BUILD_DEBUG
"Set to ON to build in Debug"
OFF
OPTION
ScalFMM_BUILD_DEBUG
OFF
@@ -95,7 +94,9 @@ if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel")
#-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ")
else
else
# NOT INTEL
# NOT INTEL
SET
ScaLFMM_CXX_FLAGS
ScaLFMM_CXX_FLAGS
-Wzero-as-null-pointer-constant"
if
NOT
ScalFMM_USE_MPI
SET
ScaLFMM_CXX_FLAGS
ScaLFMM_CXX_FLAGS
endif
SET
AVX_FLAGS
"-mtune=native -march=native"
SET
AVX_FLAGS
IF
APPLE
IF
APPLE
SET
SSE_FLAGS
"-msse3 -mfpmath=sse"
# -mtune=native -march=native
SET
SSE_FLAGS
@@ -160,16 +161,7 @@ if( ScalFMM_ATTACHE_SOURCE )
# ADD_DEFINITIONS(-g)
SET
ScaLFMM_CXX_FLAGS
ScaLFMM_CXX_FLAGS
-g"
SET
ScaLFMM_CXX_FLAGS
ScaLFMM_CXX_FLAGS
-g"
endif
endif
# Trace #
MESSAGE
STATUS
"ScalFMM_USE_TRACE =
ScalFMM_USE_TRACE
if
ScalFMM_USE_TRACE
OPTION
ScalFMM_USE_ITAC
"Set to ON to use itac trace"
OFF
if
ScaLFMM_USE_ITAC
ADD_DEFINITIONS
-I$VT_ROOT/include -trace
endif
endif
# Blas option #
# Blas option #
0ca11347
@@ -16,7 +16,7 @@
@@ -16,7 +16,7 @@
#include "Utils/FGlobal.hpp"
#include "Utils/FTrace.hpp"
#include "Utils/FPoint.hpp"
#include "Adaptative/FAdaptiveCell.hpp"
0ca11347
@@ -20,7 +20,7 @@
@@ -20,7 +20,7 @@
#include "Utils/FAssert.hpp"
#include "Utils/FLog.hpp"
#include "Utils/FTic.hpp"
#include "Containers/FOctree.hpp"
@@ -70,9 +70,7 @@ public:
* To execute the fmm algorithm
* Call this function to run the complete algorithm
void
execute
const
unsigned
operationsToProceed
FFmmNearAndFarFields
void
execute
const
unsigned
operationsToProceed
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
if
operationsToProceed
FFmmP2M
bottomPass
if
operationsToProceed
FFmmP2M
bottomPass
if
operationsToProceed
FFmmM2M
upwardPass
if
operationsToProceed
FFmmM2M
upwardPass
@@ -90,8 +88,7 @@ private:
/** P2M */
/** P2M */
void
bottomPass
void
bottomPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -125,8 +122,7 @@ private:
/** M2M */
/** M2M */
void
upwardPass
void
upwardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -205,9 +201,7 @@ private:
/** M2L */
/** M2L */
void
transferPass
void
transferPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Downward Pass (M2L)
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -299,8 +293,7 @@ private:
/** L2L */
/** L2L */
void
downardPass
void
downardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Downward Pass (L2L)
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -360,8 +353,7 @@ private:
/** P2P */
/** P2P */
void
directPass
void
directPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounterL2P
FLOG
FTic
0ca11347
@@ -16,7 +16,7 @@
@@ -16,7 +16,7 @@
0ca11347
@@ -22,7 +22,7 @@
@@ -22,7 +22,7 @@
#include "FAbstractKernels.hpp"
#include "../Containers/FOctree.hpp"
#include "../Utils/FGlobal.hpp"
#include "../Utils/FTrace.hpp"
0ca11347
@@ -20,7 +20,7 @@
@@ -20,7 +20,7 @@
#include "../Utils/FAssert.hpp"
#include "../Utils/FLog.hpp"
#include "../Utils/FTic.hpp"
@@ -71,8 +71,6 @@ public:
void
execute
const
unsigned
operationsToProceed
void
execute
const
unsigned
operationsToProceed
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
if
operationsToProceed
FFmmP2M
bottomPass
if
operationsToProceed
FFmmP2M
bottomPass
if
operationsToProceed
FFmmM2M
upwardPass
if
operationsToProceed
FFmmM2M
upwardPass
@@ -91,7 +89,6 @@ private:
/** P2M */
/** P2M */
void
bottomPass
void
bottomPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -118,7 +115,6 @@ private:
/** M2M */
/** M2M */
void
upwardPass
void
upwardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -160,8 +156,6 @@ private:
/** M2L */
/** M2L */
void
transferPass
void
transferPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -204,7 +198,6 @@ private:
/** L2L */
/** L2L */
void
downardPass
void
downardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -244,7 +237,6 @@ private:
/** P2P */
/** P2P */
void
directPass
void
directPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
FLOG
FTic
0ca11347
@@ -6,7 +6,7 @@
@@ -6,7 +6,7 @@
#include "../Utils/FGlobalPeriodic.hpp"
#include "../Utils/FMemUtils.hpp"
@@ -69,7 +69,6 @@ public:
void
execute
const
unsigned
operationsToProceed
void
execute
const
unsigned
operationsToProceed
FAssertLF
kernels
"kernels cannot be null"
FAssertLF
kernels
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
if
operationsToProceed
FFmmP2M
bottomPass
if
operationsToProceed
FFmmP2M
bottomPass
@@ -93,7 +92,6 @@ public:
/** P2M */
/** P2M */
void
bottomPass
void
bottomPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -120,7 +118,6 @@ public:
/** M2M */
/** M2M */
void
upwardPass
void
upwardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -161,8 +158,6 @@ public:
/** M2L L2L */
/** M2L L2L */
void
transferPass
void
transferPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -201,7 +196,6 @@ public:
void
downardPass
// second L2L
void
downardPass
// second L2L
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -239,7 +233,6 @@ public:
/** P2P */
/** P2P */
void
directPass
void
directPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
FLOG
FTic
@@ -513,7 +506,6 @@ public:
* Finally the L2L
* Finally the L2L
void
processPeriodicLevels
void
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Periodic Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Periodic Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
0ca11347
@@ -20,7 +20,7 @@
@@ -20,7 +20,7 @@
@@ -84,7 +84,6 @@ public:
void
execute
const
unsigned
operationsToProceed
void
execute
const
unsigned
operationsToProceed
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
#pragma omp parallel
@@ -119,7 +118,6 @@ private:
/** P2M */
/** P2M */
void
bottomPass
void
bottomPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -148,7 +146,6 @@ private:
/** M2M */
/** M2M */
void
upwardPass
void
upwardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -189,8 +186,6 @@ private:
/** M2L L2L */
/** M2L L2L */
void
transferPass
void
transferPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -241,7 +236,6 @@ private:
void
downardPass
// second L2L
void
downardPass
// second L2L
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -280,7 +274,6 @@ private:
/** P2P */
/** P2P */
void
directPass
void
directPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
@@ -330,7 +323,6 @@ private:
void
L2PPass
void
L2PPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start L2P Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start L2P Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
0ca11347
@@ -20,7 +20,7 @@
@@ -20,7 +20,7 @@
void
execute
const
unsigned
operationsToProceed
void
execute
const
unsigned
operationsToProceed
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
if
operationsToProceed
FFmmP2M
bottomPass
if
operationsToProceed
FFmmP2M
bottomPass
@@ -104,7 +103,6 @@ private:
/** P2M */
/** P2M */
void
bottomPass
void
bottomPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -138,7 +136,6 @@ private:
/** M2M */
/** M2M */
void
upwardPass
void
upwardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Upward Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -185,7 +182,6 @@ private:
/** M2L L2L */
/** M2L L2L */
void
transferPass
void
transferPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -241,7 +237,6 @@ private:
void
downardPass
// second L2L
void
downardPass
// second L2L
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -286,7 +281,6 @@ private:
/** P2P */
/** P2P */
void
directPass
void
directPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Direct Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
FLOG
FTic
computationCounter
FLOG
FTic
computationCounter
0ca11347
@@ -19,7 +19,7 @@
@@ -19,7 +19,7 @@
@@ -92,7 +92,6 @@ public:
void
execute
const
unsigned
operationsToProceed
void
execute
const
unsigned
operationsToProceed
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
for
int
idxShape
idxShape
SizeShape
idxShape
for
int
idxShape
idxShape
SizeShape
idxShape
this
shapeLeaf
idxShape
this
shapeLeaf
idxShape
@@ -132,7 +131,6 @@ private:
/** P2M */
/** P2M */
void
bottomPass
void
bottomPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FLog
Controller
write
\t
Start Bottom Pass
\n
write
FLog
Flush
FLOG
FTic
counterTime
FLOG
FTic
counterTime
@@ -169,7 +167,6 @@ private:
/** M2M */
/** M2M */
void
upwardPass
void
upwardPass
FTRACE
FTrace
FFunction
functionTrace
__FUNCTION__
"Fmm"
__FILE__
__LINE__
