Commit 065e8bef authored by Quentin Khan's avatar Quentin Khan
parents 822a2d93 1c06aca1
...@@ -113,9 +113,9 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -113,9 +113,9 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
IF (APPLE) IF (APPLE)
set(SSE_FLAGS "-msse4 -mfpmath=sse") # -mtune=native -march=native set(SSE_FLAGS "-msse4 -mfpmath=sse") # -mtune=native -march=native
else(APPLE) else(APPLE)
set(AVX_FLAGS "-mavx") set(AVX_FLAGS "-mavx -march=native")
set(AVX2_FLAGS "-mavx2") set(AVX2_FLAGS "-mavx2 -march=native")
set(SSE_FLAGS "-axSSE4.2") set(SSE_FLAGS "-axSSE4.2 -march=native")
endif(APPLE) endif(APPLE)
#-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ") #-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ")
else() else()
...@@ -179,15 +179,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -179,15 +179,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
# Release flags # # Release flags #
set(CMAKE_BUILD_TYPE Release) set(CMAKE_BUILD_TYPE Release)
# force -O3 in release
set(CMAKE_CXX_FLAGS_RELEASE "${CMAKE_CXX_FLAGS_RELEASE} -O3")
string(REPLACE "-O2" "-O3" CMAKE_CXX_FLAGS_RELEASE ${CMAKE_CXX_FLAGS_RELEASE} )
set(CMAKE_CXX_FLAGS_TYPE "${CMAKE_CXX_FLAGS_RELEASE}") set(CMAKE_CXX_FLAGS_TYPE "${CMAKE_CXX_FLAGS_RELEASE}")
# if compiler is intel add -ip # if compiler is intel add -ip
if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel") if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel")
set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} -ip") set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} -ip -no-prec-div -no-prec-sqrt")
# set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} -ip -no-prec-div -no-prec-sqrt")
endif() endif()
# Compile optimization # Compile optimization
if(APPLE) if(APPLE)
...@@ -195,11 +193,11 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -195,11 +193,11 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
"Set your optimization flags for release mode.") "Set your optimization flags for release mode.")
# Not apple system - Check the compiler flags # Not apple system - Check the compiler flags
# set(SCALFMM_FLAGS_OPTI_RELEASE "-fp-model precise -fp-model source -fimf-precision=low -funroll-loops -ftree-vectorize" set(SCALFMM_FLAGS_OPTI_RELEASE "-fp-model precise -fp-model source -fimf-precision=low -funroll-loops -ftree-vectorize"
# CACHE STRING "Set your optimization flags for release mode.") CACHE STRING "Set your optimization flags for release mode.")
set(SCALFMM_FLAGS_OPTI_RELEASE " " CACHE STRING # set(SCALFMM_FLAGS_OPTI_RELEASE "-funroll-loops -ftree-vectorize" CACHE STRING
"Set your optimization flags for release mode.") # "Set your optimization flags for release mode.")
else() else()
set(SCALFMM_FLAGS_OPTI_RELEASE "-ffast-math -funroll-loops -ftree-vectorize" CACHE STRING set(SCALFMM_FLAGS_OPTI_RELEASE "-ffast-math -funroll-loops -ftree-vectorize" CACHE STRING
...@@ -208,6 +206,9 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -208,6 +206,9 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${SCALFMM_FLAGS_OPTI_RELEASE}") set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${SCALFMM_FLAGS_OPTI_RELEASE}")
endif() endif()
MESSAGE(STATUS " %%%%%%%%%% SCALFMM_CXX_FLAGS ${SCALFMM_CXX_FLAGS} %%%%%%%%%%%%%")
MESSAGE(STATUS " %%%%%%%%%% CMAKE_CXX_FLAGS_RELEASE ${CMAKE_CXX_FLAGS_RELEASE} %%%%%%%%%%%%%")
# Attach source code to exec # # Attach source code to exec #
...@@ -537,15 +538,20 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -537,15 +538,20 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
${SCALFMM_CMAKE_MODULE_PATH}/compileTestAvx.cpp ${SCALFMM_CMAKE_MODULE_PATH}/compileTestAvx.cpp
COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS} ${AVX_FLAGS}" COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS} ${AVX_FLAGS}"
OUTPUT_VARIABLE COMPILE_AVX_OUTPUT) OUTPUT_VARIABLE COMPILE_AVX_OUTPUT)
if(${COMPILE_AVX}) if(${COMPILE_AVX})
message(STATUS "%%%%%%%%%%%% COMPILE_AVX = ${COMPILE_AVX} %%%%< ${AVX_FLAGS}")
set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${AVX_FLAGS}") set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${AVX_FLAGS}")
#set( SCALFMM_USE_SSE OFF FORCE) # ne marche pas message(STATUS "%%%%%%%%%%%% SCALFMM_CXX_FLAGS = ${SCALFMM_CXX_FLAGS}")
try_compile(COMPILE_RESULT_AVSPE ${CMAKE_CURRENT_BINARY_DIR} try_compile(COMPILE_RESULT_AVSPE ${CMAKE_CURRENT_BINARY_DIR}
${SCALFMM_CMAKE_MODULE_PATH}/checkAVXpe.cpp ${SCALFMM_CMAKE_MODULE_PATH}/checkAVXpe.cpp
COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS} ${AVX_FLAGS}") COMPILE_DEFINITIONS "${CMAKE_CXX_FLAGS} ${AVX_FLAGS}")
if( NOT ${COMPILE_RESULT_AVSPE}) if( NOT ${COMPILE_RESULT_AVSPE})
set(__AVXPE_INTEL_COMPILER ON) set(__AVXPE_INTEL_COMPILER ON)
endif() endif()
message(STATUS ${CMAKE_CXX_FLAGS} ) message(STATUS ${CMAKE_CXX_FLAGS} )
else(${COMPILE_AVX}) else(${COMPILE_AVX})
...@@ -770,7 +776,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -770,7 +776,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
#set(CMAKE_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${CMAKE_CXX_FLAGS}") #set(CMAKE_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${CMAKE_CXX_FLAGS}")
message(STATUS "SCALFMM_USE_BLAS = ${SCALFMM_USE_BLAS}") message(STATUS "SCALFMM_USE_BLAS = ${SCALFMM_USE_BLAS}")
message(STATUS "SCALFMM_USE_FFT = ${SCALFMM_USE_FFT}") message(STATUS "SCALFMM_USE_FFT = ${SCALFMM_USE_FFT}")
message(STATUS "SCALFMM_USE_MKL = TODO") message(STATUS "SCALFMM_USE_MKL = ${SCALFMM_USE_MKL}")
message(STATUS "CMAKE_CXX_FLAGS = ${CMAKE_CXX_FLAGS}") message(STATUS "CMAKE_CXX_FLAGS = ${CMAKE_CXX_FLAGS}")
message(STATUS "SCALFMM_CXX_FLAGS = ${SCALFMM_CXX_FLAGS}") message(STATUS "SCALFMM_CXX_FLAGS = ${SCALFMM_CXX_FLAGS}")
...@@ -150,7 +150,8 @@ int main(int argc, char* argv[]) ...@@ -150,7 +150,8 @@ int main(int argc, char* argv[])
KernelClass kernels(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(),&MatrixKernel); KernelClass kernels(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(),&MatrixKernel);
FmmClass algo(&tree, &kernels); // false : dynamic schedule.
FmmClass algo(&tree, &kernels,true);
algo.execute(); // Here the call of the FMM algorithm algo.execute(); // Here the call of the FMM algorithm
...@@ -80,12 +80,12 @@ public: ...@@ -80,12 +80,12 @@ public:
* The constructor needs the octree and the kernels used for computation. * The constructor needs the octree and the kernels used for computation.
* \param inTree the octree to work on. * \param inTree the octree to work on.
* \param inKernels the kernels to call. * \param inKernels the kernels to call.
* \param inStaticSchedule Whether to use static or dynamic OpenMP scheduling. * \param inStaticSchedule Whether to use static or dynamic OpenMP scheduling. default is dynamic.
* \except An exception is thrown if one of the arguments is NULL. * \except An exception is thrown if one of the arguments is NULL.
FFmmAlgorithmThread(OctreeClass* const inTree, KernelClass* const inKernels, FFmmAlgorithmThread(OctreeClass* const inTree, KernelClass* const inKernels,
const bool inStaticSchedule = true, const int inLeafLevelSeperationCriteria = 1) const bool inStaticSchedule = false, const int inLeafLevelSeperationCriteria = 1)
: tree(inTree) , kernels(nullptr), iterArray(nullptr), leafsNumber(0), : tree(inTree) , kernels(nullptr), iterArray(nullptr), leafsNumber(0),
MaxThreads(omp_get_max_threads()), OctreeHeight(tree->getHeight()), MaxThreads(omp_get_max_threads()), OctreeHeight(tree->getHeight()),
staticSchedule(inStaticSchedule), leafLevelSeperationCriteria(inLeafLevelSeperationCriteria) { staticSchedule(inStaticSchedule), leafLevelSeperationCriteria(inLeafLevelSeperationCriteria) {
