Commit f78d560e authored by Emmanuel Thomé's avatar Emmanuel Thomé
hhmmm, after all the doc was still right on this one.
parent d4915ed2
...@@ -508,8 +508,7 @@ in 128 seconds WCT. ...@@ -508,8 +508,7 @@ in 128 seconds WCT.
On grvingt-1.nancy.grid5000.fr we do a fraction 64/2^39 in time 266 On grvingt-1.nancy.grid5000.fr we do a fraction 64/2^39 in time 266
seconds WCT (2.1 GHz per core, 64 hyperthreads). seconds WCT (2.1 GHz per core, 64 hyperthreads).
The following curve was found by job `24165/2^36` (TODO: fix this, it is The following curve was found by job `24165/2^36`
(no longer) the right number).
# C=CocksPinchVariantResult(5,10000000147,0xe000000000008000,1,ht=3,hy=0x11e36418c7c8b454,max_B1=600) # C=CocksPinchVariantResult(5,10000000147,0xe000000000008000,1,ht=3,hy=0x11e36418c7c8b454,max_B1=600)
# card_E = 2^2 * p405 * r # card_E = 2^2 * p405 * r
