Commit e0c4b808 authored by MASSON Simon's avatar MASSON Simon
Merge branch 'master' of gitlab.inria.fr:smasson/cocks-pinch-variant
parents 0c3f7d60 2ef7f847
...@@ -143,6 +143,8 @@ class BLS12(EllipticCurve_finite_field): ...@@ -143,6 +143,8 @@ class BLS12(EllipticCurve_finite_field):
def u(self): def u(self):
return self._u return self._u
def T(self):
return self._u
def p(self): def p(self):
return self._p return self._p
def r(self): def r(self):
...@@ -153,6 +155,8 @@ class BLS12(EllipticCurve_finite_field): ...@@ -153,6 +155,8 @@ class BLS12(EllipticCurve_finite_field):
return self._tr return self._tr
def y(self): def y(self):
return self._y return self._y
def D(self):
return self._D
def a(self): def a(self):
return self._a # 0 return self._a # 0
def ap(self): def ap(self):
...@@ -144,6 +144,8 @@ class BN(EllipticCurve_finite_field): ...@@ -144,6 +144,8 @@ class BN(EllipticCurve_finite_field):
def T(self):
return self._u
...@@ -154,6 +156,8 @@ class BN(EllipticCurve_finite_field): ...@@ -154,6 +156,8 @@ class BN(EllipticCurve_finite_field):
def D(self):
return self._D
...@@ -256,6 +256,8 @@ class CocksPinch6(EllipticCurve_finite_field): ...@@ -256,6 +256,8 @@ class CocksPinch6(EllipticCurve_finite_field):
def T(self):
return self._u
...@@ -266,6 +268,8 @@ class CocksPinch6(EllipticCurve_finite_field): ...@@ -266,6 +268,8 @@ class CocksPinch6(EllipticCurve_finite_field):
def D(self):
return self._D
...@@ -19,7 +19,7 @@ from PairingFriendlyCurve import print_parameters, print_parameters_for_RELIC ...@@ -19,7 +19,7 @@ from PairingFriendlyCurve import print_parameters, print_parameters_for_RELIC
class CocksPinch8(EllipticCurve_finite_field): class CocksPinch8(EllipticCurve_finite_field):
A Cocks-Pinch curve of embedding degree k=8, D=8, rho=2 and optimal ate pairing available. A Cocks-Pinch curve of embedding degree k=8, D=4, rho=2 and optimal ate pairing available.
def __init__(self, u, hy, ht, exp_tr=None, p=None, r=None, c=None, tr=None, y=None, a=None, beta=None, lamb=None): def __init__(self, u, hy, ht, exp_tr=None, p=None, r=None, c=None, tr=None, y=None, a=None, beta=None, lamb=None):
...@@ -262,6 +262,8 @@ class CocksPinch8(EllipticCurve_finite_field): ...@@ -262,6 +262,8 @@ class CocksPinch8(EllipticCurve_finite_field):
def D(self):
return self._D
...@@ -124,6 +124,8 @@ class CocksPinch_k(EllipticCurve_finite_field): ...@@ -124,6 +124,8 @@ class CocksPinch_k(EllipticCurve_finite_field):
def T(self):
return self._u
...@@ -134,6 +136,8 @@ class CocksPinch_k(EllipticCurve_finite_field): ...@@ -134,6 +136,8 @@ class CocksPinch_k(EllipticCurve_finite_field):
def D(self):
return self._D
Fotiadis-Konstantinou curve with k=8, rho=2 and D=4
From the papers https://eprint.iacr.org/2018/1017.pdf
(for the curves)
k = 8; D = 4; rho = 2; #quartic twists, V = [x, -1, 0, 0], x = 0 (mod 2)
px = (x^8 + x^6 + 5*x^4 + x^2 + 4*x + 4)/4
rx = x^4 + 1
tx = x^4 + x + 2
yx = (x^3 - x^2)/2 #remove the /2 if you consider D=1
cx = (x^4+x^2)/4
beta = (x^6 - x^5 - 2*x^3 + 3*x^2 - 3*x - 2)/4
lamb = x^2
https://eprint.iacr.org/2018/969.pdf
https://eprint.iacr.org/2019/555.pdf
(for pairing computation estimates)
Rx = [1, 0, 0, 0, 1] # u^4 + 1
Rx_den = 1
Tx= [2, 1, 0, 0, 1]
Tx_den = 1
Px = [4, 4, 1, 0, 5, 0, 1, 0, 1]
Px_den = 4
Yx = [0, 0, -1, 1]
Yx_den = 2
Cx = [0, 0, 1, 0, 1]
Cx_den = 4
BETAx = [-2, -3, 3, -2, 0, -1, 1]
BETAx_den = 4
LAMBx = [0,0,1] # x^2 mod r(x) = x^4+1
LAMBx_den = 1
import sage
from exceptions import ValueError
from sage.functions.log import log
from sage.functions.other import ceil
from sage.functions.other import sqrt
from sage.arith.misc import XGCD, xgcd
from sage.rings.integer import Integer
from sage.rings.finite_rings.finite_field_constructor import FiniteField
from sage.rings.polynomial.polynomial_ring_constructor import PolynomialRing
from sage.schemes.elliptic_curves.ell_finite_field import EllipticCurve_finite_field
from sage.schemes.elliptic_curves.constructor import EllipticCurve
import PairingFriendlyCurve
from PairingFriendlyCurve import get_curve_parameter_a_j1728, get_curve_generator_order_r_j1728
class FK8D4(EllipticCurve_finite_field):
A Fotiadis-Konstantinou curve of embedding degree k=8, D=4, rho=2
def __init__(self, u, a=None):
u is the seed s.t. p=P(u), r=R(u), t=T(u)
:param u : seed
:param a : curve parameter in E: y^2 = x^3 + a*x (optional)
self._k = 8 # embedding degree
self._D = 4 # curve discriminant
self._b = 0
self._u = Integer(u)
# see bottom of file for formulas
self.polynomial_r = [1, 0, 0, 0, 1] # u^4 + 1
self.polynomial_r_denom = Integer(1)
self.polynomial_tr= [2, 1, 0, 0, 1]
self.polynomial_tr_denom = Integer(1)
self.polynomial_p = [4, 4, 1, 0, 5, 0, 1, 0, 1]
self.polynomial_p_denom = Integer(4)
self.polynomial_y = [0, 0, -1, 1]
self.polynomial_y_denom = Integer(2)
self.polynomial_c = [0, 0, 1, 0, 1]
self.polynomial_c_denom = Integer(4)
self.polynomial_beta = [-2, -3, 3, -2, 0, -1, 1]
self.polynomial_beta_denom = Integer(4)
self.polynomial_lamb = [0,0,1] # x^2 mod r(x) = x^4+1
self.polynomial_lamb_denom = Integer(1)
self._p = sum([Integer(self.polynomial_p[i])*self._u**i for i in range(len(self.polynomial_p))])//self.polynomial_p_denom
self._pbits = self._p.nbits()
self._r = sum([Integer(self.polynomial_r[i])*self._u**i for i in range(len(self.polynomial_r))])//self.polynomial_r_denom
self._c = sum([Integer(self.polynomial_c[i])*self._u**i for i in range(len(self.polynomial_c))])//self.polynomial_c_denom
self._tr= sum([Integer(self.polynomial_tr[i])*self._u**i for i in range(len(self.polynomial_tr))])//self.polynomial_tr_denom
if not self._c * self._r == self._p + 1 - self._tr:
raise ValueError("Error: r*c != p+1-tr\nr={}\nc={}\np+1-tr={}\n".format(self._r,self._c,self._p+1-self._tr))
self._y = sum([Integer(self.polynomial_y[i])*self._u**i for i in range(len(self.polynomial_y))])//self.polynomial_y_denom
# GLV parameter for fast scalar multiplication thanks to automorphism
# psi: (x,y) -> (-x,i*y) = [lambda mod r]*(x,y) if (x,y) is of order r
# where beta is a root of x^2+1 mod p, beta = sqrt(-1) mod p
# and lambda is a root of x^2+1 mod r, lamb = sqrt(-1) mod r
# there are two choices: beta, -beta, and the same for lamb: lamb, -lamb
# arbitrarily the positive ones are chosen
# if u is odd, beta has integer coefficients,
# but if u is even, then beta has denomiator 2: use / instead of //
if (self._u % 2) == 0:
self._beta = sum([Integer(self.polynomial_beta[i])*self._u**i for i in range(len(self.polynomial_beta))])/self.polynomial_beta_denom
else:
self._beta = sum([Integer(self.polynomial_beta[i])*self._u**i for i in range(len(self.polynomial_beta))])//self.polynomial_beta_denom
# lamb is always an integer
self._lamb = sum([Integer(self.polynomial_lamb[i])*self._u**i for i in range(len(self.polynomial_lamb))])//self.polynomial_lamb_denom
try:
self._Fp = FiniteField(self._p)
except ValueError as err:
print("ValueError creating Fp: {}".format(err))
raise
except:
print("Error creating Fp")
raise
if not self._r.is_prime():
raise ValueError("Error r is not prime")
# if u is even, beta has denominator 2, reduces mod p:
if (self._u %2) == 0:
self._beta = Integer(self._Fp(self._beta))
if ((self._beta**2 + 1) % self._p) != 0:
raise ValueError("Error beta^2 + 1 != 0 mod p")
if ((self._lamb**2 + 1) % self._r) != 0:
raise ValueError("Error lamb^2 + 1 != 0 mod r")
self._Fpz = PolynomialRing(self._Fp, names=('z',))
(self._z,) = self._Fpz._first_ngens(1)
self._bp = self._Fp(0) # second curve parameter is 0 because j=1728
if a != None:
try:
a = Integer(a)
except:
raise
self._a = a
self._ap = self._Fp(a)
else:
# check that beta = U/V, where U=t/2, V = y
self._a, self._ap = get_curve_parameter_a_j1728(self._tr, self._y, self._beta, self._p, self._Fp)
# Now self._a is such that E: y^2 = x^3 + a*x has order r
try:
# this init function of super inherits from class EllipticCurve_generic defined in ell_generic.py
# __init__ method inherited from ell_generic
EllipticCurve_finite_field.__init__(self, self._Fp, [0,0,0,self._ap,0])
print("ValueError at EllipticCurve_finite_field.__init__: {}".format(err))
raise
except:
print("An error occupred when initialising the elliptic curve")
raise
self.order_checked = super(FK8D4,self).order()
if self.order_checked != (self._p+1-self._tr):
print("Error, wrong order")
raise ValueError("Wrong curve order: this one is a twist")
# computes a generator
self._G = get_curve_generator_order_r_j1728(self)
self._Gx = self._G[0]
self._Gy = self._G[1]
# adjust beta and lamb according to the curve
# do we have (-x,beta*y) = lamb*(x,y)?
if self([-self._Gx, self._Gy*self._beta]) != self._lamb*self._G:
print("adjusting beta, lambda")
if self([-self._Gx, self._Gy*(-self._beta)]) == self._lamb*self._G:
self._beta = self._p-self._beta
print("beta -> -beta")
elif self([-self._Gx, self._Gy*self._beta]) == (-self._lamb)*self._G:
self._lamb = -self._lamb
print("lamb -> -lamb")
elif self([-self._Gx, self._Gy*(-self._beta)]) == (-self._lamb)*self._G:
else:
raise ValueError("Error while adjusting beta, lamb: compatibility not found")
def _repr_(self):
return "FK8D4 p"+str(self._pbits)+" (Fotiadis-Konstantinou k=8) curve with seed "+str(self._u)+"\n"+super(FK8D4,self)._repr_()
def u(self):
return self._u
def T(self):
return self._u
def p(self):
return self._p
def r(self):
return self._r
def c(self):
return self._c
def tr(self):
return self._tr
def y(self):
return self._y
def D(self):
return self._D
def a(self):
return self._a # Integer
def ap(self):
return self._ap # in Fp (finite field element)
def b(self):
return self._b # 0
def bp(self):
return self._bp # 0
def beta(self):
return self._beta
def lamb(self):
return self._lamb
def k(self):
return self._k
def Fp(self):
return self._Fp
def Fpz(self):
return self._Fpz, self._z
def G(self):
return self._G
def print_parameters(self):
PairingFriendlyCurve.print_parameters(self)
def print_parameters_for_RELIC(self):
PairingFriendlyCurve.print_parameters_for_RELIC(self)
...@@ -148,6 +148,8 @@ class KSS16(EllipticCurve_finite_field): ...@@ -148,6 +148,8 @@ class KSS16(EllipticCurve_finite_field):
def T(self):
return self._u
...@@ -158,6 +160,8 @@ class KSS16(EllipticCurve_finite_field): ...@@ -158,6 +160,8 @@ class KSS16(EllipticCurve_finite_field):
def D(self):
return self._D
return self._a # Integer return self._a # Integer
...@@ -130,6 +130,8 @@ class MNT6(EllipticCurve_finite_field): ...@@ -130,6 +130,8 @@ class MNT6(EllipticCurve_finite_field):
def T(self):
return self._u
...@@ -140,6 +142,8 @@ class MNT6(EllipticCurve_finite_field): ...@@ -140,6 +142,8 @@ class MNT6(EllipticCurve_finite_field):
def D(self):
return self._D
...@@ -177,10 +177,14 @@ def print_parameters(E): ...@@ -177,10 +177,14 @@ def print_parameters(E):
print("u ={: d}".format(E._u)) print("u ={: d}".format(E._u))
print("p ={: d}".format(E._p)) print("p ={: d}".format(E._p))
print("r ={: d}".format(E._r)) print("r ={: d}".format(E._r))
print("t ={: d}".format(E._tr))
print("y ={: d}".format(E._y))
print("c ={: d} # cofactor".format(E._c)) print("c ={: d} # cofactor".format(E._c))
print("u ={: #x}".format(E._u)) print("u ={: #x}".format(E._u))
print("p ={: #x}".format(E._p)) print("p ={: #x}".format(E._p))
print("r ={: #x}".format(E._r)) print("r ={: #x}".format(E._r))
print("t ={: #x}".format(E._tr))
print("y ={: #x}".format(E._y))
print("c ={: #x} # cofactor".format(E._c)) print("c ={: #x} # cofactor".format(E._c))
print("log_2 p ={0:8.2f}, p {1:5d} bits".format(float(log(E._p,2)), E._p.nbits())) print("log_2 p ={0:8.2f}, p {1:5d} bits".format(float(log(E._p,2)), E._p.nbits()))
print("log_2 p^k ={0:8.2f}, p^k {1:5d} bits".format(float(E._k*log(E._p,2)), (E._p**E._k).nbits())) print("log_2 p^k ={0:8.2f}, p^k {1:5d} bits".format(float(E._k*log(E._p,2)), (E._p**E._k).nbits()))
...@@ -193,11 +197,15 @@ def print_parameters_for_RELIC(E): ...@@ -193,11 +197,15 @@ def print_parameters_for_RELIC(E):
# fill at 16 hexa digits, + 2 for the 'prefix '0x' makes 18 characters # fill at 16 hexa digits, + 2 for the 'prefix '0x' makes 18 characters
print("P{0} {1:0=-#018x}".format(i, pi)) print("P{0} {1:0=-#018x}".format(i, pi))
i+=1 i+=1
g,u0,v0 = xgcd(E._p,2**64) # p_w = p-wordsize rounded to largest machine word
if abs(u0) > abs(v0): # we need the inverse of -p, not of p
u0,v0 = v0,u0 # so either
#g,u0,v0 = xgcd(E._p,2**64) # g = u0*p + v0*2**64
#u0 = 2**64 - u0
# or directly:
g,u0,v0 = xgcd(-E._p,2**64) # g = u0*p + v0*2**64
if u0 < 0: if u0 < 0:
u0 = -u0; v0 = -v0 u0 = 2**64+u0
print("U0 {:0=-#018x}".format(u0)) print("U0 {:0=-#018x}".format(u0))
#params for the ep module in RELIC #params for the ep module in RELIC
Tanaka-Nakamula curves k=8 D=4 rho=1.5
Published at Pairing'2008
k = 8; D = 4; rho = 1.5; #quartic twists available
rx = 2*x^4 + 4*x^3 + 6*x^2 + 4*x + 1
tx = 2*x^3 + 2*x^2 + 4*x + 2
yx = 3*x^3 + 5*x^2 + 7*x + 3
px = 10*x^6 + 32*x^5 + 72*x^4 + 94*x^3 + 85*x^2 + 46*x + 10
cx = 5*x^2 + 6*x + 9
twx= 10*x^6 + 32*x^5 + 72*x^4 + 96*x^3 + 87*x^2 + 50*x + 13
beta = 70*x^5 + 184*x^4 + 396*x^3 + 424*x^2 + 341*x + 117
lamb = 4*x^3 + 6*x^2 + 8*x + 3
# do not import with "from TN8 import *" but use "import TN8" and then "TN8.Px"
Rx = [1, 4, 6, 4, 2]
Tx= [2, 4, 2, 2]
Yx = [3, 7, 5, 3]
Px = [10, 46, 85, 94, 72, 32, 10]
Cx = [9, 6, 5]
BETAx = [117, 341, 424, 396, 184, 70]
LAMBx = [3, 8, 6, 4]
import sage
class TN8(EllipticCurve_finite_field):
A Tanaka-Nakamula curve of embedding degree k=8, D=4 rho=1.5
Pairing 2008
:param u : seed, should be odd
self._b = 0
self.polynomial_r = [1, 4, 6, 4, 2]
self.polynomial_tr= [2, 4, 2, 2]
self.polynomial_y = [3, 7, 5, 3]
self.polynomial_p = [10, 46, 85, 94, 72, 32, 10]
self.polynomial_c = [9, 6, 5]
self.polynomial_beta = [117, 341, 424, 396, 184, 70]
self.polynomial_lamb = [3, 8, 6, 4]
self.polynomial_y_denom = Integer(1)
self.polynomial_p_denom = Integer(1)
self.polynomial_c_denom = Integer(1)
self.polynomial_beta_denom = Integer(1)
try:
raise
except:
raise
if a != None:
try:
a = Integer(a)
except:
raise
self._a = a
else:
try:
raise
except:
raise
self.order_checked = super(TN8,self).order()
else:
def _repr_(self):
return "TN8 p"+str(self._pbits)+" (Tanaka-Nakamula k=8) curve with seed "+str(self._u)+"\n"+super(TN8,self)._repr_()
def u(self):
return self._u
def T(self):
return self._u
def p(self):
return self._p
def r(self):
return self._r
def c(self):
return self._c
def tr(self):
return self._tr
def y(self):
return self._y
def D(self):
return self._D
def a(self):
def ap(self):
def b(self):
return self._b # 0
def bp(self):
return self._bp # 0
def beta(self):
return self._beta
def lamb(self):
return self._lamb
def k(self):
return self._k
def Fp(self):
return self._Fp
def Fpz(self):
def G(self):
return self._G
ZZx.<x> = ZZ[]
k=8
ux = 2*x^3 + 4*x^2 + 6*x + 3
Phi8 = cyclotomic_polynomial(k)
Phi8(ux).factor()
rx = (2*x^4 + 4*x^3 + 6*x^2 + 4*x + 1)
tx = (ux^3+1) % rx
# yx = (tx-2)/sqrt(-D)
sqrt_D = ux^2 % rx
#g, u, v = xgcd(sqrt_D, rx)
#g == u*sqrt_D + v*rx
#inv_sqrt_D = u/ZZ(g)
inv_sqrt_D = sqrt_D # 1/sqrt(-1) = -sqrt(-1)
assert ((inv_sqrt_D^2 + 1) % rx) == 0
yx = ((tx-2)*inv_sqrt_D/2) % rx
px = (tx^2 + 4*yx^2)/4
assert tx^2 - 4*px == -4*yx^2
assert (px+1-tx) % rx == 0
cx = (px+1-tx)//rx
assert Phi8(px) % rx == 0
twx = px+1+tx
lamb = sqrt_D
# sqrt(-1) mod px <-> tx/yx -> invert yx mod px
g,u,v = xgcd(yx,px)
g == u*yx + v*px
inv_yx = u/ZZ(g)
beta = tx*inv_yx/2 % px
assert ((beta^2 +1) % rx) == 0
assert ((lamb^2 +1) % px) == 0
print("rx = {}".format(rx))
print("tx = {}".format(tx))
print("yx = {}".format(yx))
print("px = {}".format(px))
print("cx = {}".format(cx))
print("twx= {}".format(twx))
print("beta = {}".format(beta))
print("lamb = {}".format(lamb))
print("R = {}".format(rx.list()))
print("T = {}".format(tx.list()))
print("Y = {}".format(yx.list()))
print("P = {}".format(px.list()))
print("C = {}".format(cx.list()))
print("TW= {}".format(twx.list()))
print("BETA = {}".format(beta.list()))
print("LAMB = {}".format(lamb.list()))
...@@ -224,6 +224,83 @@ class TestPairingFriendlyCurve(): ...@@ -224,6 +224,83 @@ class TestPairingFriendlyCurve():
# outside the class # outside the class
