Commit a9092423 authored by MASSON Simon's avatar MASSON Simon
Merge branch 'master' of gitlab.inria.fr:smasson/cocks-pinch-variant
parents 8bb205a9 d4915ed2
...@@ -404,11 +404,11 @@ def chain_alternate_iterators(gp, gm, with_zero=False): ...@@ -404,11 +404,11 @@ def chain_alternate_iterators(gp, gm, with_zero=False):
# promises. # promises.
class CocksPinchVariantResult(object): class CocksPinchVariantResult(object):
sage: C=CocksPinchVariantResult(6,3,34359607296,5,ht=0x101,hy=2,max_B1=1000) sage: C=CocksPinchVariantResult(6,3,34359607296,5,ht=0x101,hy=-2,max_B1=1000)
sage: C.E2(factor=True)["text_factorization"] sage: C.E2(factor=True)["text_factorization"]
'2^2 * 3 * 19 * 73 * 163 * 33637 * p48 * r' '2^2 * 3 * 19 * 73 * 163 * 33637 * p48 * r'
sage: C=CocksPinchVariantResult(6,3,0x600100002,5,ht=0x428,hy=0x639,allowed_cofactor=420,max_B1=600) sage: C=CocksPinchVariantResult(6,3,0x600100002,5,ht=0x428,hy=-0x639,allowed_cofactor=420,max_B1=600)
sage: C.is_small_subgroup_secure() sage: C.is_small_subgroup_secure()
True True
sage: C.is_twist_small_subgroup_secure() sage: C.is_twist_small_subgroup_secure()
...@@ -457,17 +457,17 @@ class CocksPinchVariantResult(object): ...@@ -457,17 +457,17 @@ class CocksPinchVariantResult(object):
sage: (C.is_small_subgroup_secure(), C.is_twist_small_subgroup_secure(), C.is_G2_small_subgroup_secure(), C.is_twist_G2_small_subgroup_secure()) sage: (C.is_small_subgroup_secure(), C.is_twist_small_subgroup_secure(), C.is_G2_small_subgroup_secure(), C.is_twist_G2_small_subgroup_secure())
(True, True, True, True) (True, True, True, True)
sage: C=CocksPinchVariantResult(6,3,0x600081000,1,ht=-0x191,hy=-0x7e2) sage: C=CocksPinchVariantResult(6,3,0x600081000,1,ht=-0x191,hy=0x7e2)
sage: C.set_test_info(allowed_size_cofactor=10) sage: C.set_test_info(allowed_size_cofactor=10)
sage: C=CocksPinchVariantResult(5,10000000147,0xe000000000008000,1,ht=3,hy=-0x11e36418c7c8b454,max_B1=600) sage: C=CocksPinchVariantResult(5,10000000147,0xe000000000008000,1,ht=3,hy=0x11e36418c7c8b454,max_B1=600)
sage: C=CocksPinchVariantResult(6,3,0xfffffffffffffff00000000000000000,1,ht=0x43fff,hy=-0xffffffffff800007fffe,allowed_size_cofactor=10,max_B1=600) sage: C=CocksPinchVariantResult(6,3,0xfffffffffffffff00000000000000000,1,ht=0x43fff,hy=0xffffffffff800007fffe,allowed_size_cofactor=10,max_B1=600)
...@@ -487,11 +487,11 @@ class CocksPinchVariantResult(object): ...@@ -487,11 +487,11 @@ class CocksPinchVariantResult(object):
sage: C=CocksPinchVariantResult(7,20,0x5ec7fc01ff8,4,ht=-3,hy=-1,allowed_size_cofactor=10,max_B1=600) sage: C=CocksPinchVariantResult(7,20,0x5ec7fc01ff8,4,ht=-3,hy=1,allowed_size_cofactor=10,max_B1=600)
(True, True, False, False) (True, True, False, False)
sage: C=CocksPinchVariantResult(8,4,0xffffffffffffffc0,1,ht=-0x1821f,hy=0x1fdc,allowed_cofactor=1232,allowed_size_cofactor=10,max_B1=600) sage: C=CocksPinchVariantResult(8,4,0xffffffffffffffc0,1,ht=-0x1821f,hy=-0x1fdc,allowed_cofactor=1232,allowed_size_cofactor=10,max_B1=600)
...@@ -1837,7 +1837,7 @@ class CocksPinchVariantSearch(object): ...@@ -1837,7 +1837,7 @@ class CocksPinchVariantSearch(object):
# (sqrt((PP/2 - t^2)/D) + y1) / ry <= -pre_hy < (sqrt(PP - t^2)/D) + y1) / ry # (sqrt((PP/2 - t^2)/D) + y1) / ry <= -pre_hy < (sqrt(PP - t^2)/D) + y1) / ry
if PP < t**2: if PP < t**2:
continue continue
pre_hymax = 1+floor(((sqrt((PP - t**2)/fD) - y1)/ry)) pre_hymax = 1+floor(((sqrt((PP - t**2)/fD) - y1)/ry))
mpre_hymax = 1+floor(((sqrt((PP - t**2)/fD) + y1)/ry)) mpre_hymax = 1+floor(((sqrt((PP - t**2)/fD) + y1)/ry))
if PP/2 < t**2: if PP/2 < t**2:
This diff is collapsed.
