Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit c000b56c authored by Emmanuel Thomé's avatar Emmanuel Thomé
more doc
parent 7257c5ad
Cocks--Pinch curves with embedding degree 5 to 8 and optimal ate pairing
This repository holds companion code for the paper.
We provide code for the following tasks.
* Search for pairing-friendly curves with our Cocks-Pinch variant; see
"Using the search program")
* Generate formulas for efficient computation of final exponentiations
when k is either 5 or 7 (see file `final_expo_k57.py`) or 6 or 8
(`final_expo_k68.sage`). For all four cases, see also the section
"Formulas for final exponentiation" in this file.
* Generate tables with estimated costs of pairing computations for
various embedding degrees. See "Computing pairing costs"
Using the search program Using the search program
...@@ -563,3 +579,50 @@ respectively): ...@@ -563,3 +579,50 @@ respectively):
Note that the former is naturally preferred because hy has 2-naf weight Note that the former is naturally preferred because hy has 2-naf weight
only 4. only 4.
This corresponds to §5.2 of the paper.
For the cases `k=5` and `k=7`, the file `final_expo_k57.py` contains
explicit formulas that reach the upper bound claimed in §5.2 in the
paper.
To reproduce this, one does as follows. Notice that the number of
inversions depends on the parameter `i`.
sage: load("final_expo_k57.py")
sage: print_final_expo_k57()
cost for k=5 i=1: 3p + 1c + 7M + 3T
cost for k=5 i=2: 1I + 3p + 1c + 7M + 3T
cost for k=5 i=3: 2I + 3p + 1c + 7M + 3T
cost for k=5 i=4: 1I + 3p + 1c + 7M + 3T
cost for k=7 i=1: 5p + 1c + 11M + 5T
cost for k=7 i=2: 1I + 5p + 1c + 11M + 5T
cost for k=7 i=3: 1I + 5p + 1c + 11M + 5T
cost for k=7 i=4: 2I + 5p + 1c + 11M + 5T
cost for k=7 i=5: 2I + 5p + 1c + 11M + 5T
cost for k=7 i=6: 1I + 5p + 1c + 11M + 5T
For the cases `k=6` and `k=8`, the exact formulas depend on the chosen
CM discriminant, and employ further optimizations. Formulas as well as
costs, matching those found in §5.2 in the paper, can be obtained as
follows:
sage: load("final_expo_k68.sage")
sage: formulas(6)
[lots of output]
sage: formulas(8)
[lots of output]
Tables 5 and 9 in the paper are also generated automatically. The
following code can be used.
sage: load("cost_pairing.py")
sage: table_costFpk([1,2,3,5,6,7,8,12,16])
sage: table_cost_pairing()
...@@ -2,9 +2,9 @@ from sage.all_cmdline import * ...@@ -2,9 +2,9 @@ from sage.all_cmdline import *
from CocksPinchVariant import * from CocksPinchVariant import *
import sage.rings.integer import sage.rings.integer
from BLS12 import * from BLS12 import *
from BLS24 import * # from BLS24 import *
from KSS16 import * from KSS16 import *
from KSS18 import * # from KSS18 import *
from BN import * from BN import *
from MNT6 import * from MNT6 import *
from final_expo_k57 import * from final_expo_k57 import *
...@@ -171,7 +171,7 @@ def table_costFpk(k_list): ...@@ -171,7 +171,7 @@ def table_costFpk(k_list):
r"\end{array}$$", r"\end{array}$$",
print "% This table is generated by:" print "% This table is generated by:"
print "%% PYTHONPATH=code/ sage -c 'load(\"code/cost_pairing.py\"); table_costFpk(%s)'" % (k_list) print "%% PYTHONPATH=cocks-pinch-variant/ sage -c 'load(\"cocks-pinch-variant/cost_pairing.py\"); table_costFpk(%s)'" % (k_list)
for s in contents: for s in contents:
print s print s
...@@ -229,11 +229,11 @@ def finite_field_cost(logp): ...@@ -229,11 +229,11 @@ def finite_field_cost(logp):
def is_one_of_our_known_pairing_friendly_curves(C): def is_one_of_our_known_pairing_friendly_curves(C):
return isinstance(C, BN) or \ return isinstance(C, BN) or \
isinstance(C, BLS12) or \ isinstance(C, BLS12) or \
isinstance(C, BLS24) or \
isinstance(C, KSS16) or \ isinstance(C, KSS16) or \
isinstance(C, KSS18) or \
isinstance(C, MNT6) or \ isinstance(C, MNT6) or \
False; False;
# isinstance(C, BLS24) or \
# isinstance(C, KSS18) or \
def polymorphic_get_logp(C): def polymorphic_get_logp(C):
if is_one_of_our_known_pairing_friendly_curves(C): if is_one_of_our_known_pairing_friendly_curves(C):
...@@ -264,12 +264,12 @@ def polymorphic_get_name(C): ...@@ -264,12 +264,12 @@ def polymorphic_get_name(C):
return 'MNT6' return 'MNT6'
elif isinstance(C, BLS12): elif isinstance(C, BLS12):
return 'BLS12' return 'BLS12'
elif isinstance(C, BLS24): # elif isinstance(C, BLS24):
return 'BLS24' # return 'BLS24'
elif isinstance(C, KSS16): elif isinstance(C, KSS16):
return 'KSS16' return 'KSS16'
elif isinstance(C, KSS18): # elif isinstance(C, KSS18):
return 'KSS18' # return 'KSS18'
elif isinstance(C, Integer): elif isinstance(C, Integer):
return '$k=1$' return '$k=1$'
else: else:
...@@ -280,9 +280,9 @@ def polymorphic_get_miller_loop_length(C): ...@@ -280,9 +280,9 @@ def polymorphic_get_miller_loop_length(C):
return C.T return C.T
elif isinstance(C, BN): elif isinstance(C, BN):
return 6*C.u()+2 return 6*C.u()+2
elif isinstance(C, BLS12) or isinstance(C, BLS24): elif isinstance(C, BLS12): # or isinstance(C, BLS24):
return C.tr() - 1 return C.tr() - 1
elif isinstance(C, KSS16) or isinstance(C, KSS18): elif isinstance(C, KSS16): # or isinstance(C, KSS18):
return C.u() return C.u()
elif isinstance(C, MNT6): elif isinstance(C, MNT6):
# lazy me # lazy me
...@@ -679,7 +679,7 @@ def table_cost_pairing() : ...@@ -679,7 +679,7 @@ def table_cost_pairing() :
#timing recap is generated #timing recap is generated
print "% PYTHONPATH=code sage -c 'load(\"code/cost_pairing.py\"); table_cost_pairing()" print "% PYTHONPATH=cocks-pinch-variant sage -c 'load(\"cocks-pinch-variant/cost_pairing.py\"); table_cost_pairing()"
def wrap_cell(cell): def wrap_cell(cell):
return "\\begin{tabular}{@{}c@{}} %s \\end{tabular}" % cell return "\\begin{tabular}{@{}c@{}} %s \\end{tabular}" % cell
