Commit 3c37e8cc authored by Nikos Makris's avatar Nikos Makris Committed by SAUCEZ Damien
Fixes for running the master branch on the UTH nodes
parent 76b47f83
1 merge request!2Fixes for running the master branch on the UTH nodes
...@@ -2,6 +2,23 @@ ...@@ -2,6 +2,23 @@
## Deployment node ## Deployment node
```console
sudo apt install docker.io
If there is no id_rsa file, create it with the following command:
```console
ssh-keygen -t rsa
Then copy the .pub file to the $HOME/.ssh/authorized_hosts of all the nodes that will be managed by the deployment container
cat $HOME/.ssh/id_rsa.pub
To build the deployment container:
```console ```console
docker build -t deployment_node -f Dockerfile . docker build -t deployment_node -f Dockerfile .
...@@ -47,4 +64,4 @@ ansible-playbook -i inventories/staging --extra-vars "@params.yaml" --extra-vars ...@@ -47,4 +64,4 @@ ansible-playbook -i inventories/staging --extra-vars "@params.yaml" --extra-vars
## Deploy 5G network ## Deploy 5G network
ansible-playbook -i inventories/staging --extra-vars "@params.yaml" --extra-vars "@params.5g.yaml" --extra-vars "@secrets.yaml" --ask-vault-pass 5g.yaml ansible-playbook -i inventories/staging --extra-vars "@params.yaml" --extra-vars "@params.5g.yaml" --extra-vars "@secrets.yaml" --ask-vault-pass 5g.yaml
\ No newline at end of file
...@@ -4,7 +4,8 @@ ...@@ -4,7 +4,8 @@
prometheus_basic_auth_password: "{{ secrets['prometheus_basic_auth_password'] }}" prometheus_basic_auth_password: "{{ secrets['prometheus_basic_auth_password'] }}"
grafana_password: "{{ secrets['grafana_password'] }}" grafana_password: "{{ secrets['grafana_password'] }}"
roles: roles:
- docker/tasks
- grafana-loki-prometheus/prometheus - grafana-loki-prometheus/prometheus
- grafana-loki-prometheus/loki - grafana-loki-prometheus/loki
- grafana-loki-prometheus/grafana - grafana-loki-prometheus/grafana
...@@ -134,7 +134,7 @@ def render(templatepath, gcn): ...@@ -134,7 +134,7 @@ def render(templatepath, gcn):
# load configurations # load configurations
with open('roles/5g/templates/manifest.yaml', "r") as file: with open('roles/5g/base/templates/manifest.yaml', "r") as file:
tpls = yaml.safe_load(file) tpls = yaml.safe_load(file)
core = yaml.safe_load(os.environ['params_5g']) core = yaml.safe_load(os.environ['params_5g'])
...@@ -157,4 +157,4 @@ for item in tpls["templates"]: ...@@ -157,4 +157,4 @@ for item in tpls["templates"]:
content = render(path, gcn) content = render(path, gcn)
else: else:
content = readFile("/".join([tpls["output_dir"], path ])) content = readFile("/".join([tpls["output_dir"], path ]))
createFile(content, item['output']) createFile(content, item['output'])
...@@ -10,8 +10,8 @@ ...@@ -10,8 +10,8 @@
args: args:
chdir: oai-cn5g-fed chdir: oai-cn5g-fed
- name: generate OAI files - name: generate OAI files
ansible.builtin.shell: python3 roles/5g/files/gen_oai.py ansible.builtin.shell: python3 roles/5g/base/files/gen_oai.py
environment: environment:
params_5g: params_5g:
GCN: '{{ GCN }}' GCN: '{{ GCN }}'
...@@ -39,4 +39,4 @@ ...@@ -39,4 +39,4 @@
# # Deploy the UE # # Deploy the UE
# - name: Deploy the UE # - name: Deploy the UE
# ansible.builtin.include_tasks: 'ue.yaml' # ansible.builtin.include_tasks: 'ue.yaml'
# when: GCN.UE is defined and GCN.UE.present # when: GCN.UE is defined and GCN.UE.present
output_dir: roles/5g/templates/oai-cn5g-fed/charts output_dir: roles/5g/base/templates/oai-cn5g-fed/charts
templates: templates:
- template: oai-5g-core/oai-5g-basic/config.yaml.j2 - template: oai-5g-core/oai-5g-basic/config.yaml.j2
output: ./oai-cn5g-fed/charts/oai-5g-core/oai-5g-basic/config.yaml output: ./oai-cn5g-fed/charts/oai-5g-core/oai-5g-basic/config.yaml
...@@ -22,4 +22,4 @@ templates: ...@@ -22,4 +22,4 @@ templates:
- template: oai-5g-ran/oai-gnb/templates/configmap.yaml - template: oai-5g-ran/oai-gnb/templates/configmap.yaml
output: ./oai-cn5g-fed/charts/oai-5g-ran/oai-gnb/templates/configmap.yaml output: ./oai-cn5g-fed/charts/oai-5g-ran/oai-gnb/templates/configmap.yaml
- template: oai-5g-ran/oai-gnb/templates/deployment.yaml - template: oai-5g-ran/oai-gnb/templates/deployment.yaml
output: ./oai-cn5g-fed/charts/oai-5g-ran/oai-gnb/templates/deployment.yaml output: ./oai-cn5g-fed/charts/oai-5g-ran/oai-gnb/templates/deployment.yaml
...@@ -21,11 +21,11 @@ spec: ...@@ -21,11 +21,11 @@ spec:
- containerPort: 8080 - containerPort: 8080
resources: resources:
limits: limits:
cpu: 200m cpu: 300m
memory: 200Mi memory: 400Mi
requests: requests:
cpu: 100m cpu: 150m
memory: 100Mi memory: 200Mi
volumeMounts: volumeMounts:
- name: rootfs - name: rootfs
mountPath: /rootfs mountPath: /rootfs
