@@ -28,4 +28,4 @@ To do that, you have to export your project from the other GitLab instance and i
# limitations:
# limitations:
* users can create up to 50 projects
* project size are limited to 2GB
* GitLab's integrated continuous integration is deactivated by default. Nothing prevents you to enable it on a per project basis, but then you're on your own, we do not currently provide support for this. More specifically we do not yet provide support for interfacing GitLab with Inria's continuous integration platform.
* GitLab's integrated continuous integration is enabled by default on all projects, but we do not currently provide support for this. More specifically we do not yet provide support for interfacing GitLab with Inria's continuous integration platform.
