... | @@ -154,7 +154,7 @@ gitlab-runner status # should return "service is running" |
### Register a runner in your project
On the virtual machine where you installed the gitlab CI runner, run (as root or sudo!) :
On the virtual machine where you installed the gitlab CI runner, run (as root or sudo if the gitlab-runner program has been installed with sudo, remove sudo from the following if not) :
$ sudo gitlab-runner register
