Update gitlab-runner install for macOS (ci user) authored by HUYNH Kim-Tam's avatar HUYNH Kim-Tam
...@@ -143,9 +143,13 @@ sudo gitlab-runner status # should return "service is running" ...@@ -143,9 +143,13 @@ sudo gitlab-runner status # should return "service is running"
#### Installation example on a macOS slave from ci.inria.fr ("ci" user account) #### Installation example on a macOS slave from ci.inria.fr ("ci" user account)
**[Limitations on macOS](https://docs.gitlab.com/runner/install/osx.html#limitations-on-macos)** : The service needs to be installed from a Terminal window logged in as your current user (i.e., "ci" user account).
sudo curl --output /usr/local/bin/gitlab-runner https://gitlab-runner-downloads.s3.amazonaws.com/latest/binaries/gitlab-runner-darwin-amd64 sudo curl --output /usr/local/bin/gitlab-runner https://gitlab-runner-downloads.s3.amazonaws.com/latest/binaries/gitlab-runner-darwin-amd64
sudo chmod +x /usr/local/bin/gitlab-runner sudo chmod +x /usr/local/bin/gitlab-runner
# Run the following commands as the "ci" user
gitlab-runner install --working-directory /builds gitlab-runner install --working-directory /builds
gitlab-runner start gitlab-runner start
gitlab-runner status # should return "service is running" gitlab-runner status # should return "service is running"
