Commit c7e42bcc authored by GILLES Sebastien's avatar GILLES Sebastien
Add in the README a quick description of both Dockerfiles.
parent 4a79d692
...@@ -6,3 +6,8 @@ docker build -f docker/<dockerfile> . ...@@ -6,3 +6,8 @@ docker build -f docker/<dockerfile> .
The .dockerignore file is used to reduce docker image size by keeping the docker context to minimum. The .dockerignore file is used to reduce docker image size by keeping the docker context to minimum.
There are two Dockerfiles here:
- [Dockerfile], which creates an image with a Conda environment to run properly Xeus-cling.
- [Dockerfile-full], which creates an image with a Conda environment to run properly Xeus-cling and installs as well local compilers so that they may be invoked from the notebooks (for the 6-InRealEnvironment part).
