Commit 33b66aed authored by GILLES Sebastien's avatar GILLES Sebastien
Types notebook: add the possibility to declare std::string from string...
Types notebook: add the possibility to declare std::string from string litterals with 's' suffix (I learned that while preparing string view notebooks).
parent 388bebbb
...@@ -690,7 +690,36 @@ ...@@ -690,7 +690,36 @@
"cell_type": "markdown", "cell_type": "markdown",
"source": [ "source": [
"Please notice C++17 introduced [std::string_view](https://en.cppreference.com/w/cpp/header/string_view) which is more efficient than `std::string` for some operations (it is presented [in appendix](../7-Appendix/StringView.ipynb) but if it's your first reading it's a bit early to tackle it now).\n" "FYI, C++ 14 introduced a suffix to facilitate declaration of a `std::string` from a string litterals... but which requires to add a specific `using namespace` first (we will see that those are in a [much later notebook](../6-InRealEnvironment/5-Namespace.ipynb)). "
"execution_count": null,
"#include <string>\n",
"using namespace std::string_literals;\n",
"auto hello_str = \"Hello world\"; // declares a char*\n",
"auto hello = \"Hello world\"s; // declares a std::string - requires first the using namespace directive\n",
"std::string hello_string(\"Hello world\"); // the 'classic' way to define a std::string"
"Not sure it it is entirely worth it (maybe when you define loads of `std::string` is a same file?) but you may see that in an existing program."
"FYI as well, C++17 introduced [std::string_view](https://en.cppreference.com/w/cpp/header/string_view) which is more efficient than `std::string` for some operations (it is presented [in appendix](../7-Appendix/StringView.ipynb) but if it's your first reading it's a bit early to tackle it now)."
