Attention une mise à jour du service Gitlab va être effectuée le mardi 14 décembre entre 13h30 et 14h00. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit 33b66aed authored by GILLES Sebastien's avatar GILLES Sebastien
Types notebook: add the possibility to declare std::string from string...
Types notebook: add the possibility to declare std::string from string litterals with 's' suffix (I learned that while preparing string view notebooks).
parent 388bebbb
......@@ -690,7 +690,36 @@
"Please notice C++17 introduced [std::string_view](https://en.cppreference.com/w/cpp/header/string_view) which is more efficient than `std::string` for some operations (it is presented [in appendix](../7-Appendix/StringView.ipynb) but if it's your first reading it's a bit early to tackle it now).\n"
"FYI, C++ 14 introduced a suffix to facilitate declaration of a `std::string` from a string litterals... but which requires to add a specific `using namespace` first (we will see that those are in a [much later notebook](../6-InRealEnvironment/5-Namespace.ipynb)). "
"execution_count": null,
"#include <string>\n",
"using namespace std::string_literals;\n",
"auto hello_str = \"Hello world\"; // declares a char*\n",
"auto hello = \"Hello world\"s; // declares a std::string - requires first the using namespace directive\n",
"std::string hello_string(\"Hello world\"); // the 'classic' way to define a std::string"
"Not sure it it is entirely worth it (maybe when you define loads of `std::string` is a same file?) but you may see that in an existing program."
"FYI as well, C++17 introduced [std::string_view](https://en.cppreference.com/w/cpp/header/string_view) which is more efficient than `std::string` for some operations (it is presented [in appendix](../7-Appendix/StringView.ipynb) but if it's your first reading it's a bit early to tackle it now)."
