Commit 327955c3 authored by Vicente Mataix Ferrándiz's avatar Vicente Mataix Ferrándiz 🐍
Compile with master
parent 48ad3dd2
...@@ -8,9 +8,9 @@ build_docker: ...@@ -8,9 +8,9 @@ build_docker:
retry: 2 retry: 2
tags: tags:
- linux - linux
rules: only:
- changes: refs:
- docker/Dockerfile - master
script: script:
- docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY - docker login -u $CI_REGISTRY_USER -p $CI_REGISTRY_PASSWORD $CI_REGISTRY
- docker build -f docker/Dockerfile -t $CI_REGISTRY/$CI_PROJECT_PATH:latest . - docker build -f docker/Dockerfile -t $CI_REGISTRY/$CI_PROJECT_PATH:latest .
...@@ -22,9 +22,9 @@ build_docker_full: ...@@ -22,9 +22,9 @@ build_docker_full:
retry: 2 retry: 2
tags: tags:
- linux - linux
rules: only:
- changes: refs:
- docker/Dockerfile_full - master
script: script:
- docker build -f docker/Dockerfile_full -t $CI_REGISTRY/$CI_PROJECT_PATH:full . - docker build -f docker/Dockerfile_full -t $CI_REGISTRY/$CI_PROJECT_PATH:full .
