Commit bc11fe0b authored by GILLES Sebastien's avatar GILLES Sebastien
#1397 Changing shell does not work; go back to former version (and enrich bash profile).
parent 9b9e37be
Pipeline #71552 canceled with stages
in 36 minutes and 37 seconds
...@@ -42,7 +42,6 @@ stages: ...@@ -42,7 +42,6 @@ stages:
paths: paths:
- build/compilation.log - build/compilation.log
script: script:
- zsh
- mkdir -p build - mkdir -p build
- source activate Python3 - source activate Python3
- cd build && python ../cmake/Scripts/configure_cmake.py --cache_file=../cmake/PreCache/macos_apple_clang.cmake --cmake_args="-G Ninja" --third_party_directory=/Volumes/Data/ci/opt/${MODE} --mode=${MODE} --library_type=${LIB_NATURE} --morefem_as_single_library=${IS_ONLY_ONE_LIB} - cd build && python ../cmake/Scripts/configure_cmake.py --cache_file=../cmake/PreCache/macos_apple_clang.cmake --cmake_args="-G Ninja" --third_party_directory=/Volumes/Data/ci/opt/${MODE} --mode=${MODE} --library_type=${LIB_NATURE} --morefem_as_single_library=${IS_ONLY_ONE_LIB}
