Commit b512d30f authored by GILLES Sebastien's avatar GILLES Sebastien
Issue tag v19.48.
parent 99468970
...@@ -3,6 +3,13 @@ means week 46 of year 2013. Should a second tag be given the same week, an index ...@@ -3,6 +3,13 @@ means week 46 of year 2013. Should a second tag be given the same week, an index
Starting from v18.47, the ticket numbers in bold are those that might break compatibility in models. Starting from v18.47, the ticket numbers in bold are those that might break compatibility in models.
# v19.48
- Bug #1498 - #1292: Fix remaining warnings, and a stupid bug I inroduced in visco-elasticity in the conversion from Seldon to Xtensor.
- Bug #1499: Improve the exception handling within SNESSolve: previously if an exception was thrown inside the static functions provided to SNES, the exceptions were not caught properly and the program exited poorly.
# v19.45.1 # v19.45.1
- Documentation #1497: Fix a tiny bug that prevented run of GitlabPages. - Documentation #1497: Fix a tiny bug that prevented run of GitlabPages.
