Commit 88fe432d authored by GILLES Sebastien's avatar GILLES Sebastien
#1360 Gitlab-CI: update the two other images under test.
parent c4f2fd36
...@@ -38,7 +38,7 @@ build-Ubuntu-debug-shared-several_libs: ...@@ -38,7 +38,7 @@ build-Ubuntu-debug-shared-several_libs:
- several_libs - several_libs
script: script:
- mkdir -p build - mkdir -p build
- cd build && cmake -G Ninja -C ../cmake/PreCache/ci_linux.cmake -DCMAKE_BUILD_TYPE=Debug -DLIBRARY_TYPE=SHARED -DBUILD_MOREFEM_UNIQUE_LIBRARY=False -DCMAKE_INSTALL_PREFIX=/media/suppl_drive/opt/debug/shared/several_libs/ .. - cd build && python ../cmake/Scripts/configure_cmake.py --cache_file=../cmake/PreCache/linux.cmake --cmake_args="-G Ninja" --install_directory=/media/suppl_drive/opt/debug/shared/several_libs/ --third_party_directory /media/suppl_drive/opt
- ninja -j 4 - ninja -j 4
build-Fedora-release-static-unique_lib: build-Fedora-release-static-unique_lib:
...@@ -55,7 +55,7 @@ build-Fedora-release-static-unique_lib: ...@@ -55,7 +55,7 @@ build-Fedora-release-static-unique_lib:
- unique_lib - unique_lib
script: script:
- cd build && cmake -G Ninja -C ../cmake/PreCache/ci_linux.cmake -DCMAKE_BUILD_TYPE=Release -DLIBRARY_TYPE=STATIC -DBUILD_MOREFEM_UNIQUE_LIBRARY=True -DCMAKE_INSTALL_PREFIX=/media/suppl_drive/opt/release/static/unique_lib .. - cd build && python ../cmake/Scripts/configure_cmake.py --cache_file=../cmake/PreCache/linux.cmake --cmake_args="-G Ninja" --install_directory=/media/suppl_drive/opt/release/static/unique_lib/ --third_party_directory /media/suppl_drive/opt --mode="Release" --library_type="static" --morefem_as_single_library=True
Supports Markdown
