Commit 7357c6f9 authored by GILLES Sebastien's avatar GILLES Sebastien
#1496 Deactivate Verrou: not yet ready (I have to figure out how to compile...
#1496 Deactivate Verrou: not yet ready (I have to figure out how to compile properly Valgrind to work in Docker images no matter what is the underlying architecture of the VM).
parent 12088d40
include:
- local: '/ExternalTools/Gitlab-CI/common.yml'
- local: '/ExternalTools/Gitlab-CI/doxygen.yml'
- local: '/ExternalTools/Gitlab-CI/build_and_test_linux.yml'
- local: '/ExternalTools/Gitlab-CI/valgrind.yml'
- local: '/ExternalTools/Gitlab-CI/verrou.yml'
- local: '/ExternalTools/Gitlab-CI/analysis.yml'
build_ubuntu_gcc_debug_several_shared_libraries:
extends: .build_template_linux
tags:
- ubuntu
- gcc
- debug
variables:
OS: "ubuntu"
COMPILER: "gcc"
MODE: "debug"
LIB_NATURE: "shared"
OS: "ubuntu"
IS_ONLY_ONE_LIB: "False"
check_ubuntu_gcc_debug_several_shared_libraries:
extends: .check_compilation_warning_template_docker
tags:
- ubuntu
- gcc
- debug
dependencies:
- build_ubuntu_gcc_debug_several_shared_libraries
variables:
OS: "ubuntu"
COMPILER: "gcc"
MODE: "debug"
OS: "ubuntu"
build_ubuntu_gcc_release_one_static_library:
tags:
- ubuntu
- gcc
- release
variables:
OS: "ubuntu"
COMPILER: "gcc"
MODE: "release"
LIB_NATURE: "static"
OS: "ubuntu"
IS_ONLY_ONE_LIB: "True"
check_ubuntu_gcc_release_one_static_library:
tags:
- ubuntu
- gcc
- release
dependencies:
- build_ubuntu_gcc_release_one_static_library
variables:
OS: "ubuntu"
COMPILER: "gcc"
MODE: "release"
OS: "ubuntu"
build_fedora_gcc_debug_one_shared_library:
tags:
- fedora
- gcc
- debug
variables:
OS: "fedora"
COMPILER: "gcc"
MODE: "debug"
OS: "fedora"
check_fedora_gcc_debug_one_shared_library:
tags:
- fedora
- gcc
- debug
dependencies:
- build_fedora_gcc_debug_one_shared_library
variables:
OS: "fedora"
COMPILER: "gcc"
MODE: "debug"
OS: "fedora"
build_fedora_gcc_release_several_static_libraries:
tags:
- fedora
- gcc
- release
variables:
OS: "fedora"
COMPILER: "gcc"
MODE: "release"
OS: "fedora"
check_fedora_gcc_release_several_static_libraries:
tags:
- fedora
- gcc
- release
dependencies:
- build_fedora_gcc_release_several_static_libraries
variables:
OS: "fedora"
COMPILER: "gcc"
MODE: "release"
OS: "fedora"
build_fedora_clang_debug_several_shared_libraries:
tags:
- fedora
- clang
- debug
variables:
OS: "fedora"
COMPILER: "clang"
MODE: "debug"
OS: "fedora"
check_fedora_clang_debug_several_shared_libraries:
tags:
- fedora
- clang
- debug
dependencies:
- build_fedora_clang_debug_several_shared_libraries
variables:
OS: "fedora"
COMPILER: "clang"
MODE: "debug"
OS: "fedora"
build_fedora_clang_release_one_static_library:
tags:
- fedora
- clang
- release
variables:
OS: "fedora"
COMPILER: "clang"
MODE: "release"
OS: "fedora"
check_fedora_clang_release_one_static_library:
tags:
- fedora
- clang
- release
dependencies:
- build_fedora_clang_release_one_static_library
variables:
OS: "fedora"
COMPILER: "clang"
MODE: "release"
OS: "fedora"
# - local: '/ExternalTools/Gitlab-CI/verrou.yml' #1496 - not ready
\ No newline at end of file
include:
# - local: '/ExternalTools/Gitlab-CI/build_and_test_linux.yml'
# - local: '/ExternalTools/Gitlab-CI/build_and_test_macos.yml'
# - local: '/ExternalTools/Gitlab-CI/doxygen.yml'
# - local: '/ExternalTools/Gitlab-CI/valgrind.yml'
# - local: '/ExternalTools/Gitlab-CI/analysis.yml'
