Commit 5d6407cc authored by GILLES Sebastien's avatar GILLES Sebastien
#167 Remove commented code.
parent a66f50f9
......@@ -87,15 +87,6 @@ namespace MoReFEM
private:
//! Check the vectors defined in Variable section are the same length; throw an exception if not.
// void CheckVariableConsistency() const;
//! Check the vectors defined in BoundaryCondition section are the same length; throw an exception if not.
// void CheckBoundaryConditionConsistency() const;
......@@ -28,38 +28,7 @@ namespace MoReFEM
: Utilities::InputDataNS::Base<InputData, TupleT>(filename,
mpi,
do_track_unused_fields)
// \todo Deactivated for the moment, see #167
// CheckVariableConsistency();
// CheckBoundaryConditionConsistency();
// template<class TupleT>
// void InputData<TupleT>::CheckVariableConsistency() const
// using SubTuple = std::tuple
// InputData::Variable::Variable,
// InputData::Variable::DegreeOfExactness
// this->template EnsureSameLength<SubTuple>();
// void InputData<TupleT>::CheckBoundaryConditionConsistency() const
// InputData::BoundaryCondition::Variable,
// InputData::BoundaryCondition::Component
} // namespace MoReFEM
