Commit 5c013dd4 authored by GILLES Sebastien's avatar GILLES Sebastien
#1292 Add Xtensor to the dependencies in CMake.
parent 9bd09a95
......@@ -55,6 +55,7 @@ include_directories(${CMAKE_CURRENT_SOURCE_DIR}/Sources /
${PARMETIS_INCL_DIR} /
${LUA_INCL_DIR} /
${BOOST_INCL_DIR} /
${XTENSOR_INCL_DIR} /
${LIBMESH_INCL_DIR}
......@@ -42,6 +42,8 @@ set(LUA_LIB_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Lua/lib CACHE PATH "Lib dir
set(BOOST_INCL_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Boost/include CACHE PATH "Include directory of Boost library.")
set(BOOST_LIB_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Boost/lib CACHE PATH "Lib directory of Boost library.")
set(XTENSOR_INCL_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Xtensor/include CACHE PATH "Include directory of Xtensor library.")
set(LIBMESH_INCL_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Libmeshb/include CACHE PATH "Include directory of Libmeshb library.")
set(LIBMESH_LIB_DIR ${MOREFEM_THIRD_PARTY_LIBRARIES_DIR}/Libmeshb/lib CACHE PATH "Lib directory of Libmeshb library.")
......@@ -152,6 +152,7 @@ If you need to change a value which is not provided in this script input, you ma
'OPEN_MPI_INCL_DIR', 'OPEN_MPI_LIB_DIR',
'PETSC_INCL_DIR', 'PETSC_LIB_DIR',
'BOOST_INCL_DIR', 'BOOST_LIB_DIR',
'XTENSOR_INCL_DIR',
'LIBMESH_INCL_DIR', 'LIBMESH_LIB_DIR',
'LIBMESH_MAJOR_VERSION',
'LUA_INCL_DIR', 'LUA_LIB_DIR',
......@@ -341,6 +342,11 @@ If you need to change a value which is not provided in this script input, you ma
"PATH",
"Path to the directory that contains the Boost library files.")
self._cache_entry("XTENSOR_INCL_DIR",
"PATH",
"Path to the directory that contains the Xtensor include files.")
self._cache_entry("LIBMESH_INCL_DIR",
"PATH",
"Path to the directory that contains the Libmesh include files.")
Supports Markdown
