GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
GILLES Sebastien
MoReFEM
33f02f55
33f02f55
DIAZ Jerome
Committed by
GILLES Sebastien
Oct 29, 2019
#1489 Added Valgrind script and corresponding stage for CI.
fd126f1f
3
ExternalTools/Gitlab-CI/analysis.yml
33f02f55
valgrind
stage
analysis
registry.gitlab.inria.fr/morefem/analysistools/valgrind:latest
script
python Scripts/Tools/run_valgrind.py
dependencies
artifacts
name
artifact_${CI_PROJECT_ID}_${CI_COMMIT_REF_SLUG}_${OS}-valgrind"
expire_in
2 days
when
always
# paths:
# - morefem-valgrind.xml
# only:
# - develop@morefem/corelibrary/morefem
# - /(sonarqube)/
cppcheck
stage
analysis
registry.gitlab.inria.fr/morefem/analysistools/cppcheck:latest
@@ -14,7 +30,8 @@ cppcheck:
only
/(sonarqube)/
rats
stage
analysis
registry.gitlab.inria.fr/morefem/analysistools/rats:latest
ExternalTools/Gitlab-CI/gitlab-ci-no-macos.yml
33f02f55
include
local
/ExternalTools/Gitlab-CI/common.yml'
local
/ExternalTools/Gitlab-CI/analysis.yml'
build_ubuntu_gcc_debug_several_shared_libraries
extends
.build_template_linux
33f02f55
import
os
import
sys
import
shutil
import
subprocess
if
__name__
"__main__"
morefem_source_dir
os
path
join
os
path
dirname
os
path
realpath
__file__
"Sources"
build_dir
os
path
join
morefem_source_dir
"build_4_valgrind"
if
os
path
exists
build_dir
shutil
rmtree
build_dir
os
mkdir
build_dir
os
chdir
build_dir
cmd
"python"
"../cmake/Scripts/configure_cmake.py"
"--cache_file=../cmake/PreCache/linux.cmake"
"--cmake_args=
-G Ninja
"--install_directory=/opt"
subprocess
Popen
cmd
shell
False
communicate
cmd
"ninja"
subprocess
Popen
cmd
shell
True
communicate
# executables_dir = os.path.join(build_dir, "Sources")
# os.chdir(executables_dir)
cmd
"valgrind --error-exitcode=1 --log-file=memcheck_matrix_operations.txt --gen-suppressions=all --show-leak-kinds=all --show-reachable=yes --track-origins=yes --leak-check=full --suppressions=${HOME}/Codes/MoReFEM/CoreLibrary/ExternalTools/Valgrind/openmpi.suppr --suppressions=${HOME}/Codes/MoReFEM/CoreLibrary/ExternalTools/Valgrind/libgomp.suppr --suppressions=${HOME}/Codes/MoReFEM/CoreLibrary/ExternalTools/Valgrind/libc.suppr Sources/MoReFEMTestPetscMatrixOperations -i ${HOME}/Codes/MoReFEM/CoreLibrary/Sources/Test/ThirdParty/PETSc/MatrixOperations/demo.lua "
subprocess
Popen
cmd
shell
True
communicate
