@@ -102,26 +102,17 @@ Contrary to Ubuntu, Fedora is shipped with fairly recent versions of compilers;
MoReFEM relies on several third party libraries:
- An optimized Blas library. On macos you may use the Accelerate framework; Openblas has also been successfully tested.
- Lua 5.1, which is required by Ops library (more on that one below).
- Lua 5.3, which is required by Ops library (more on that one below).
- Boost C++ library; Boost is present only while waiting for full support of filesystem module in libstdc++ and libc++ STL.
- Openmpi 3.0.
- Openmpi 4
- Parmetis 4.0.3 used to partition the meshes.
- SuperLU\_dist 5.2.2, ScaLAPACK v2.0.2 and Mumps 5.1.2: Solvers interfaced in Petsc.
- Petsc 3.11: The linear algebra library in charge of the large matrices and vectors. Most of the mpi heavy-lifting is in fact handled by this library. MUMPS, ScaLAPACK and SuperLU\_dist are installed through their Petsc embedded version.
- Petsc 3.8.3: The linear algebra library in charge of the large matrices and vectors. Most of the mpi heavy-lifting is in fact handled by this library.
The [ThirdPartyCompilationFactory](https://gitlab.inria.fr/MoReFEM/ThirdPartyCompilationFactory) project on gitlab provides smooth ways to install these dependencies: either by running directly a Python script or by using one of the given Docker images.
### FYI: Embedded libraries
Four libraries are embedded in MoReFEM directly (and their compilation is already handled through MoReFEM different builds systems):
-[TClap](http://tclap.sourceforge.net), a header-only library to handle command line arguments.
-[Seldon](http://seldon.sourceforge.net), a linear algebra C++ library used to hande small matrices and vectors in MoReFEM. We foresee to benchmark this library against [Xtensor](https://github.com/QuantStack/xtensor) and [Eigen](http://eigen.tuxfamily.org).
-[Xtensor](https://github.com/xtensor-stack/xtensor), a linear algebra C++ library used to hande small matrices and vectors in MoReFEM, and its dependencies / extensions ([Xtl](https://github.com/xtensor-stack/xtl), [Xsimd](https://github.com/xtensor-stack/xsimd) and [Xtensor-blas](https://github.com/xtensor-stack/xtensor-blas)).
-[Ops](https://gitlab.com/libops), a C++ library for reading configuration files.
-[Libmesh](http://pages.saclay.inria.fr/loic.marechal/libMeshb.html), a mesh utility.
