Commit 12f7e535 authored by DIAZ Jerome's avatar DIAZ Jerome Committed by GILLES Sebastien
#1489 Remove previous attempt for the valgrind job.
parent a404ab39
...@@ -16,18 +16,6 @@ build_ubuntu_gcc_debug_several_shared_libraries: ...@@ -16,18 +16,6 @@ build_ubuntu_gcc_debug_several_shared_libraries:
OS: "ubuntu" OS: "ubuntu"
IS_ONLY_ONE_LIB: "False" IS_ONLY_ONE_LIB: "False"
valgrind_memcheck:
stage: valgrind
image: ubuntu:latest
tags:
- ubuntu
- gcc
- debug
before_script:
- apt-get -y install valgrind
script:
- cd ${HOME}/Codes/MoReFEM/CoreLibrary/build/Sources
- valgrind --error-exitcode=1 --log-file=memcheck_matrix_operations.txt --gen-suppressions=all --show-leak-kinds=all --show-reachable=yes --track-origins=yes --leak-check=full --suppressions=${HOME}/Codes/MoReFEM/CoreLibrary/ExternalTools/Valgrind/openmpi.suppr --suppressions=${HOME}/Codes/MoReFEM/CoreLibrary/ExternalTools/Valgrind/libgomp.suppr --suppressions=${HOME}/Codes/MoReFEM/CoreLibrary/ExternalTools/Valgrind/libc.suppr ./MoReFEMTestPetscMatrixOperations -i ${HOME}/Codes/MoReFEM/CoreLibrary/Sources/Test/ThirdParty/PETSc/MatrixOperations/demo.lua
check_ubuntu_gcc_debug_several_shared_libraries: check_ubuntu_gcc_debug_several_shared_libraries:
extends: .check_compilation_warning_template_docker extends: .check_compilation_warning_template_docker
