Commit 01b3103a authored by ARONSSOHN Constantin's avatar ARONSSOHN Constantin Committed by MOEBEL Emmanuel
Improve default behaviour, and fix bug where the default was set to shapes...
parent bc406425
1 merge request!3Improve default behaviour, and fix bug where the default was set to shapes...
......@@ -39,12 +39,12 @@
<widget class="QComboBox" name="cb_strategy">
<item>
<property name="text">
<string>Shapes</string>
<string>Spheres</string>
</property>
</item>
<item>
</property>
</item>
</widget>
......@@ -184,7 +184,7 @@ p, li { white-space: pre-wrap; }
<item row="0" column="0">
<widget class="QLabel" name="lbl_strategy_input">
<string>Shape mask paths</string>
<string>Sphere radius list</string>
</property>
</widget>
</item>
